Power Steering Pulley Puller
Old Feb 16, 2013 | 02:58 PM
AK FORD GUY's Avatar
AK FORD GUY
I am going to buy a pulley puller in the near future. I see a couple different styles out there.
the style that has two long arms and clamps around the pulley in two spots or the style that has the full collar style clamp.
Is one better than the other and why?
Old Feb 16, 2013 | 04:44 PM
Blackfoot Big Block's Avatar
Blackfoot Big Block
I believe the second one is not only a puller but also an installer as well.
Old Feb 16, 2013 | 05:01 PM
AK FORD GUY
Correct, but the puller and installer are different parts within the kit.
I was just curious if one style was better than the other.
This one is just a puller:
Old Feb 16, 2013 | 05:18 PM
Blackfoot Big Block
AHHH,
I thought you were debating which one to purchase...
I have one like second one as a kit in a plastic case. I've used it several times and it's worked well.
It also takes less space to use it. IIRC the first time I used it was to replace a vacuum pump on a 1996 7.3 Powerstroke. I used the puller on the pulley while the pump was still bolted to the engine. I don't think I could have done that with the two arm style...
Old Feb 16, 2013 | 05:24 PM
AK FORD GUY
Thanks, that's exactly the kind of info I was looking for.
1974 f100
13
May 23, 2017 08:52 AM
jerryst
Aug 8, 2016 11:05 AM
daisyman
May 23, 2015 10:24 PM
ptr34
Oct 5, 2008 09:07 AM
cbfomoco
Nov 22, 2005 02:28 PM
