powersteering pump?pulley
Old Oct 2, 2008 | 08:05 PM
ptr34's Avatar
ptr34
how do u get it off? and which way does it turn?
Old Oct 2, 2008 | 10:05 PM
speckfisher's Avatar
speckfisher
Need to rent or buy the pulley removal tool. You don't turn it, its pressed on. Tool probably cost $30.00 or rent it cheaper
Old Oct 3, 2008 | 08:58 AM
69cj's Avatar
69cj
Free at Autozone. Leave a security deposit and there is no charge.
Old Oct 3, 2008 | 11:13 AM
OZX1's Avatar
OZX1
<table width="95%"><tbody><tr><td>SECTION 211-02: Power Steering
</td> <td align="right">2004 F-Super Duty 250-550/Excursion Workshop Manual
</td></tr> <tr><td>REMOVAL AND INSTALLATION
</td> <td align="right">Procedure revision date: 05/24/2003</td> </tr></tbody></table><hr> Power Steering Pump Pulley <sup> Printable View (168 KB)</sup>
<table width="50%" border="1" cellpadding="3" cellspacing="0"> <caption>Special Tool(s)</caption> <tbody><tr valign="top"><td></td><td valign="top"> Remover, Power Steering Pump Pulley
211-016 (T69L-10300-B) </td></tr> <tr valign="top"><td></td><td valign="top"> Installer, Power Steering Pump Pulley
211-185 (T91P-3A733-A)</td></tr></tbody></table>Removal and Installation
Vehicles with 6.0L engine
  1. Remove the engine cooling fan. For additional information, refer to Section 303-03.
All vehicles
  1. If equipped with A/C, rotate the tensioner clockwise and remove the belt from the power steering pump pulley. If not equipped with A/C, rotate the tensioner counterclockwise and remove the belt from the power steering pump pulley. For additional information, refer to Section 303-05.
Vehicles with 5.4L and 6.8L engine
  1. With the vehicle in NEUTRAL, position on a hoist. For additional information refer to Section 100-02.
All vehicles
  1. Using the special tool, remove the pulley.
    • Inspect the pulley for paint marks in the web area near the hub. If there are two paint marks, discard the pulley. If there is no paint or one paint mark, use a paint pencil to mark the web area of the pulley near the hub.
  1. To install, reverse the removal procedure.
  1. CAUTION: Replacement of the power steering pump pulley is necessary after being removed and installed two times.
    Using the special tool, install the power steering pump pulley.
<hr>
Old Oct 5, 2008 | 01:06 AM
ptr34's Avatar
ptr34
thanks guys. got it done.? do u need to bleed pump?
Old Oct 5, 2008 | 09:07 AM
69cj's Avatar
69cj
Yes, just fill to full mark and turn steering wheel lock to lock 3 or 4 times with engine running, check fluid adding as needed and repeat until fluid is stable at the full mark.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
