power steering help
Old Feb 16, 2013 | 09:32 AM
bronkntrukholik's Avatar
bronkntrukholik
power steering help
I was hauling wood out of the woods and turning my truck and trailer around in the dirt and the top hose blew out of the flange of the power steering pump (threaded part stayed in and oring and flange pulled apart), so i drove home leaking all my oil out and replaced the whole hose with a different one, i have tried countless times to bleed it out (up on jack stands lock to lock with engine off) and now it just keeps bubbling over. Does it sound like the pump went bad or am i overlooking something?
Old Feb 16, 2013 | 09:56 AM
earthquake68's Avatar
earthquake68
You have a '78-'79 1/2 ton four wheel drive, don't you?
I went through this last year. This is THE ONLY way to bleed it properly. Your parts are fine, you just have to bleed it the proper way.
https://www.ford-trucks.com/forums/1...ering-fix.html
Old Feb 16, 2013 | 02:09 PM
bronkntrukholik
Sory I didn't post that which truck, but it's my 77 1/2 ton 4x4 with a 302 in it and it has the surpentine belt set-up on it, i will have to check the ps gearbox to see which it is, it could have been swapped out too!
Old Feb 16, 2013 | 05:47 PM
earthquake68
The serpentine set up was swapped on to the truck. It didn't come that way. If you have a late model '77, you have the '78-'79 gear box. It'll be easy to tell, the power steering lines go into the BOTTOM side of the gear box.
Ford77Pickup
May 20, 2017 03:59 PM
Bigjay74
Mar 22, 2016 09:26 PM
billg302
Apr 15, 2009 11:07 PM
ozstang65
Jan 18, 2009 05:57 AM
gustaf-dgm
Mar 17, 2007 01:10 PM
