Power Steering Help Needed
Old Mar 16, 2007 | 09:12 PM
gustaf-dgm's Avatar
gustaf-dgm
Question Power Steering Help Needed
Hi,
I have an 89 F250 4x4 with a 460. While I was out plowing this evening, I seem to have sprung a leak in my PS system (haven't had a chance to look into wher it is leaking yet). When the pump started to whine, I shut the truck down immediately. I decided to fill the reservoir and get the truck home ASAP. When I started the truck up the steering extremely hard to turn but the pump was no longer whining. I got the truck home and still no whining but still extremely hard to turn.
Any thoughts? Is the pump shot or is it the steering box?
Thanks!!
Dave
Old Mar 16, 2007 | 09:42 PM
gustang818's Avatar
gustang818
The hard turning is probably air in the system that you need to bleed it out. With the motor running cycle the wheel lock to lock several times, check fluid and repeat. If it's really hard to turn, put it up on jack stands.
Here's a link that may help with locating the leak:
https://www.ford-trucks.com/forums/5...ring-pump.html
Old Mar 16, 2007 | 10:22 PM
F150xlt's Avatar
F150xlt
If the leak is where the pitman arm attaches to the sector shaft of the power steering gear box you need to replace the steering gear lower pitman shaft seal.
Costs about $17.00.
Old Mar 17, 2007 | 12:12 AM
buffalobob's Avatar
buffalobob
is the power steering belt wet with power steering fluid from the leak?..that would cause pump to not provide steering assist
Old Mar 17, 2007 | 01:10 PM
gustaf-dgm's Avatar
gustaf-dgm
I took a quick look this morning and from the top side everything looks pretty dry. I couldn't gete great look from the bottom but I suspect it might be the pitman shaft seal or the return line might have rusted through somewhere.
