Hi,I'm hoping someone can help.I have a bad hinge on my 65 f100 and i saw that Lmc sells new ones but when i called they told me they don't have it for a 65,only up to 64 i need the upper passenger hinge ,the one that has the spring to hold the door in different positions.It was my understanding that the hinges are the same for 61-66.Am i correct?
the problem i have is in the piece that the check rides on as you open and close the door,the piece that the spring compresses and the check rides on it.that piece is worn and when the door is opened it is hard and makes a popping noise
I have a bad door hinge on my 65 F100. I see that LMC sells new ones, but when I called they told me they don't have it for a 65, only up to 64.
I need the upperright (passenger) hinge, the one that has the spring to hold the door in different positions.
It was my understanding that the hinges are the same for 61-66. Am I correct? No.
But LMC isn't correct either (so what else is new?). 1961/63 and 1964 before serial number 490,001 is the same.
1964 from serial number 490,001, 1965/66 is different.
----------------------------------------------------- C4TZ-8122800-B .. Right (Passenger) Side Upper Door Hinge-Includes Door Check / Obsolete
1964 F100/1100 & N/NT/T500/1100 from serial number 490,001 / 1965/66 F100/1100 / 1965/69 N/NT/T500/1100 / 1967/69 F800/1000.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
KAMA OBSOLETE PARTS in East Bethel MN has ONE = 763-434-0123.
BOWMAN SALES & SERVICE in Bowman ND has ONE = 701-523-3257.
A set? What set? I only listed the RIGHT upper hinge: C4TZ-8122800-B .. because that's what you asked for.
LEFT upper hinge: C4TZ-8122801-B ~ KAMA OBSOLETE PARTS has ONE & WESLEY OBSOLETE PARTS has THREE (see post 4 for locations & phone numbers).
------------------------------------------------------------------------------------------------------------------------------------------------------- Right & Left lower hinges: C4TZ-8122800-A .. Reverse hinge pin for use on left side ~ KAMA has TWO & WESLEY has FOUR.
NOS PARTS LTD in Waxahachie TX has TWO = 972-937-2201.
i bought the upper left and right hinges from two different places.from the info number dummy posted .the right side hinge was 25.00 and according to them its a NOS part.That was a good deal.the other was 95.00 But i figure i will replace them both .i have bought some used ones on ebay but they turn out to be bad hinges.I have had my truck torn appart for about a year and eight months and i am in the final stretch, hopefully i will be done this spring.I would sell you the used ones,but they are not in great shape.
