'65 Steering box rebuild
Old Feb 19, 2013 | 11:51 AM
C G B's Avatar
C G B
Heya gents,
Im looking for a good teardown of a steering box for a 65 F100 2wd. Ive searched the forums, and have not been able to find a decent set of tear down instructions with pictures. I thought I would just have a go at it, but Im lost on how to actually get the thing apart. I do not want to ruin what I have, so I need to take it apart without wrecking anything. Mine has no issues beyond leaking and I just want to replace the seals so it can be repainted.
If someone has the teardown instructions, preferably with pictures, please share. If not, please share where I can get a manual, preferably on CD. When Im done with the repair, I will post some pictures of how to take it apart, and put it back together.
Thanks
Old Feb 19, 2013 | 11:58 AM
camperspecial65's Avatar
camperspecial65
Hi Corey. If you have the factory shop manual then you have the seal r&r instructions...to the best of my knowlege theres only 3 or 4 seals...but the biggy...and I think most common leak...is the pitman arm which you would need a special puller to remove and a good torque wrench to reinstall as well as large socket for the nut...IMO, I would have a shop do it...the seals are fairly easy to come by...plus if you have a shop do it, they can tell you if you need other parts replaced inside...i believe theres a couple of bearings and races that are common wear areas.
- cs65
Old Feb 19, 2013 | 12:15 PM
C G B's Avatar
C G B
@cs65
Any links on where I can get the shop manual, preferably on CD? I have the pitman arm puller and the 2 1/2" or 2 3/8" socket needed. (cant remember which socket it is )
Mine really doesnt have more than 3/4" slop in the steering wheel, so Im hoping that just replacing the seals will do it. If it needs more than that, I will cross that bridge when we get there.
Edit: Is this the correct shop manual that I should be looking for or is there something better? http://www.amazon.com/1965-Ford-Truc.../dp/1603710736
Old Feb 19, 2013 | 06:49 PM
garbz2's Avatar
garbz2
Leave it to a pro. special tools are needed to set the pre loads.
I do not rebuild my own units.
Garbz
Old Feb 19, 2013 | 07:38 PM
camperspecial65
Thats the manual you need...good price too with shipping...
- cs65
Old Feb 19, 2013 | 10:34 PM
jhooch's Avatar
jhooch
Send the unit to RedHead Steering gear in Seattle, Wa. They are the best at refurbishing these boxes.
Red Head Steering Gears - Steering Gear | Steering Gear Box
Old Feb 20, 2013 | 02:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
To the best of my knowlege there's only 3 or 4 seals.
(sigh) 1965/72 F100/250 2WD & 1967/72 F350 with manual steering: There are only two seals:
C7OZ-3591-A (replaced B6A-3591-A) .. Sector Shaft Seal / Pitman Arm attaches to sector shaft.
B5S-3738-A .. Steering Shaft & Rack Seal.
1964/72 Ford Truck Parts Catalog / Illustration Section 35.1, Page 2 (upper pic) shows the manual gearbox and all internal parts. Catalog available on a CD from hipoparts.com
Dave (garbz2) and "Squire" Don (cs65) have this catalog. Both borrowed my CD, burned copies. Don musta suffered a brain fart inre to his 3 or 4 seals malarky.
Originally Posted by C G B
Mine really doesn't have more than 3/4" of slop in the steering wheel. So I'm hoping that just replacing the seals will do it.
What in the world? Seals have nothing to do with slop (play) in the gearbox! Hell, 3/4" is nothing, I've seen some of these trucks with 6" of play in the gearbox.
Play (slop) in the gearbox caused by: Worn sector shaft and/or sector shaft bearings, worn steering shaft and rack and/or upper/lower bearings/cups.
Outside the gearbox: Worn draglink, inner/outer tie rods, king pins.
The mistake people make: They use 90 weight gear lube in the gearbox that was designed for steering gear grease! Gear lube causes the internal parts to wear out faster.
Old Feb 20, 2013 | 08:10 AM
C G B's Avatar
C G B
Jeff:
Thanks for the link for Red Head, but I will probably have to find someone local as shipping a 40lbs steering box across country is a bit pricey.
- cs65
Thats what I thought. I will order it this week. I buy alot of crap from Amazon. Free shipping and good prices are hard to beat.
Yeah, my steering box is nice and tight, but it leaks like a sieve. I just need to replace the seals. I refuse to pay $250 and give up my good steering box as a core to get back some POS that Cardone cleaned up, put new seals and grease in it for $5, and slapped some paint on it.
Duly noted on steering grease!
Old Feb 21, 2013 | 07:16 AM
NumberDummy
C7OZ-3591-A (replaced B6A-3591-A) .. Sector Shaft Seal / Obsolete
TISON MOTOR CO. in Estill SC has 8 = 803-625-2551.
WESLEY OBSOLETE PARTS in Liberty KY has 15 = 606-787-5293.
GREEN SALES CO. in Cincinnati OH has 133 = 800-543-4959.
B5S-3738-A .. Steering Shaft & Rack Seal / Obsolete
TISON MOTOR CO. has 1.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
MUSTANG'S ETC in Van Nuys CA has 18 = 818-787-7634.
Old Feb 21, 2013 | 08:09 PM
camperspecial65
I was including the top cover and large round end cap in addition to the pitman shaft and sector shaft...
- cs65
Old Feb 21, 2013 | 08:20 PM
camperspecial65
I was including the top cover etc in addition to the pitman shaft and sector shaft...
- cs65
Old Feb 22, 2013 | 06:35 AM
NumberDummy
No such thing as a Pitman Arm shaft. Pitman Arm connects to the sector shaft, sector shaft seal is C7OZ-3591-A
The only other seal (B5S-3738-A) is located at the top of the steering shaft & rack.
No seal located on the sector shaft cover, just this:
C3AZ-3581-A .. PAPER Gasket-Sector Shaft Cover / Obsolete
(sigh) Open your peepers: C5TZ-3504-D M/S Gearbox: Text, Section 35.1, Page 17 ~ Parts List # 26 // Illustration Section 35.1, Page 2 ~ 1965/72 F100/250 2WD & 1967/72 F350 C5TZ-3504-D M/S Gearbox
Old Feb 22, 2013 | 10:26 PM
DKluke's Avatar
DKluke
CGB, you can rebuild the da*& thing yourself. I got the correct part numbers and POC's from ND for the cage bearings, sector shaft bushing, lower seal and as he said, the proper grease and rebuilt mine myself for less than half the price a reman would cost. I ordered and received the complete shop manual on CD for my 1965 f100 short bed from Detroit Iron.
crneville
Oct 29, 2019 06:25 PM
53choptop
Sep 7, 2004 05:29 PM
dreamtruck
Dec 20, 2003 07:46 PM
Justio
Dec 2, 2003 05:18 PM
VespaJay
Dec 6, 2002 08:13 AM
