Late/slow shifting
Old Feb 15, 2013 | 12:20 PM
johnday's Avatar
johnday
Late/slow shifting
I just put a Roush exhaust system on, and noticed my trans shift pointes may have changed. It likely was like this before but not noticed because of the silence of the stock exhaust.
Bear with me. When shifting through the first 4 gears, the dash indicator and seat of the pants tells me it shifted, then within a couple seconds, it "feels" and sounds like it shifts again, although no indication on the dash.
It seems to wind out 4th gear for an extremely long time, as well as 5th. I've found myself backing off slightly to get it to shift, then just resume with same foot pressure.
When just before, about ten feet, of coming to a stop, the engine speeds up, you can see it on the tach, about 150 rpm's, then settles back to idle. You can even feel the truck wants to accelerate, it wouldn't be much, but I've never experienced this before.
As stated, I never noticed this before, and am having a hard time thinking the new exhaust may have caused this, but with the electronic wonderments on these trucks, I just don't know.
BTW, trans was not in the tow/haul mode, or manual.
Anyone?
Old Feb 15, 2013 | 01:04 PM
1Aauto's Avatar
1Aauto
Former Vendor
If you haven't changed the tranny fluid and filter in a while you might want to get all of the tranny fluid out of the transmission, replace it with new fluid and a fresh filter.
That may resolve the issue for you.
Old Feb 15, 2013 | 01:12 PM
johnday's Avatar
johnday
Yepper, if it was older. This thing has less than 12k miles on it. I guess I should have mentioned that, eh?
Old Feb 15, 2013 | 01:34 PM
1Aauto's Avatar
1Aauto
Former Vendor
Sorry I didn't realize that.
Old Feb 15, 2013 | 06:53 PM
tvsjr's Avatar
tvsjr
Did you pull the battery when you did the exhaust install? If so, you reset all of the information the truck "learned" about your driving style. It will feel different for a while as it re-learns.
Old Feb 16, 2013 | 08:05 AM
meborder's Avatar
meborder
the truck is responding to your new exhaust the same way your right foot is responding to the new sound.
i'm betting the truck has learned that you like the sound of your new exhaust.
i too have felt the surge close to stop you mention. if you find a fix, let me know. our subaru is terrible with that too.
Old Feb 16, 2013 | 08:48 AM
johnday's Avatar
johnday
No need for sorry, you're trying to help.
Old Feb 16, 2013 | 11:28 AM
johnday's Avatar
johnday
I had my "trusted" mechanic do the install for me. My shoulder is screwed up, so I can't work over my head for awhile. I'll call and ask him Monday. He may have, I noticed on the display that my gear display wasn't there when I got back in the truck.
Why would you disconnect the battery when doing this. It seems lately, some of the "how to's" I've read, say to disconnect the battery, pull the E brake, put in neutral, etc., etc., etc. I thought it was just protecting themselves from lawsuits from the Darwin awards class. But now I'm wondering what's next. Change out a lightbulb and do all of the above?LOL
That surge is odd for sure, if I find the fix, I'll post it.
This morning on my way home, I put the tranny in manual, and ran through the gears, shifting it when I felt it should shift, right about 1500 rpm. Then put it back to D. I noticed the next turn I made, it went down to 3rd, and then shifted closer to where I think it should. Maybe what you guys said is what it's doing. I hope, but a truck with Alzheimers? LOL
Old Feb 16, 2013 | 02:59 PM
johnday's Avatar
johnday
Just got back from a grocery run, 35 miles roundtrip, up and down hills, and a couple stopsigns. The tranny appears to be shifting as usual again, except for it shifting from 5th to 4th, and 6th to 5th. I know full well it shifted, but my display doesn't always show it. The rpm gain just before a stop, seems to be intermittent as well now.
Old Feb 16, 2013 | 05:32 PM
efx4's Avatar
efx4
My truck has always surged coming to a stop, but I have always attributed this to late down shifting along with a very short 1st gear.
Old Feb 16, 2013 | 06:29 PM
johnday's Avatar
johnday
So, you feel this is normal? I have noticed that when coming to a stop, the gear display jumps from 3rd down to 1st, skipping 2nd altogether, then I get the surge, [that's a good word for it]. At this pointe, I'm not sure I believe everything the gear display is telling me. This is what you see as well?
Old Feb 17, 2013 | 11:01 PM
Chad149's Avatar
Chad149
Hi John. Sounds like you may now be detecting the point at which the torque converter locks up while you accelerate (trans computer adapts that too). Did your tech weld the exhaust together? Battery would have been disconnected for protection of the trucks electronics.
Old Feb 18, 2013 | 07:31 AM
johnday's Avatar
johnday
Hi right back Chad. What you're saying makes sense about the torque converter. That would be why it seemed like the extra gear between shift indications. That is gone for the most part now, except going up a steep hill where you would expect the trans to downshift.
Tell me if I'm wrong, but does the torque converter lockup at the shift pointe normally? I'm going with the seat of the pants feel, and watching the tach and gear selector. I never felt that before.
Sounds like the "surge" is being caused by the torque converter unlocking just before a stop?
I guess I shouldn't have waited 12 years before buying another automatic, that 4R100 in the olde stroker never made me wonder what was going on. A lot has changed, and no one ever told me.LOL
Old Feb 18, 2013 | 08:17 AM
Chad149's Avatar
Chad149
Ford has been much more aggressive with the torque converter clutch in the quest for better mpg. In my truck' s six speed their locking it up in third, unlocking for shifts.
Old Feb 18, 2013 | 11:22 AM
johnday's Avatar
johnday
Seems things are working the way they should again. Yes, my torque converter locks up about half way through 3rd, now that I've got a better handle on how this thing works, I'm feeling better about it. The last automatic I bought, '01 SD, the trans was replaced around 26k, there was a defect with a lot of them, something about the casting/machining process, IIRC. They'd overheat and not go into 3rd. I was thinking I had another bad one, and it was only coincidental with the new exhaust.
Believe me though, I'm keeping a close eye on it, probably for a long time.
On edit; Just talked to my mechanic. The battery was not disconnected, and there was no welding. Talking with him, we think what has happened is that the ECM and other controls, are seeing a reduction in back pressure. So, since it appears all this is tied together, the truck is relearning my style of driving, just as was mentioned earlier.
Well, I've got to be more careful, I learned a few things in this thread. Thanks all.
paddler65
May 26, 2010 11:04 AM
r10kidds
Oct 25, 2009 08:08 AM
SmOkIn(EM)OUT
Oct 23, 2009 10:57 AM
jasona5150
Aug 18, 2007 02:05 PM
jfonod
1997 - 2003 F150
Apr 29, 2006 03:39 PM
