i need a pcm
Old Feb 15, 2013 | 09:32 AM
tappit01's Avatar
tappit01
i need a pcm
i have an early 99 f-350 automatic and i'm trying to find a pcm out of a newer truck so i can have more options with tuners and chips. from what i see there are several diffirent codes on them. does it matter which one i go with ? does anyone have one to sell ? or can anyone point me in the right direction. thanks chris
Old Feb 15, 2013 | 10:05 AM
BillyBob69's Avatar
BillyBob69
THere are different ones depending on what year, model etc your truck is.
What is it that you are looking to get extra from a different PCM?
Years ago when I first got my chip, I noticed that the Cruise Control indicator on the dash was lighting up when it didn't before. However...the engine "clatteerd" quite a bit more. I asked about this and the chip had to be re-programmed as it was set for a late 99 and not an early 99. Once I got it back, the indicator didn't work anymore but the truck ran alot better.
There is a base that each model, build has to follow. Getting a different PCM for a different model may not work. The E99s have a different turbo than the late 99s. So that is going to change the way the engine runs. And I think the injectors are different.
This is why I ask... What are you looking to get in addtional features?
Old Feb 15, 2013 | 10:40 AM
tappit01's Avatar
tappit01
i am wanting to go with new stage 2 injectors from ffd/cass. and new tunes from gear head. the guys at gh. dont tune e99 and the guys at ffd recomends upgrade my pcm so i can do this. does this sound right to you all?
Old Feb 15, 2013 | 10:59 AM
BillyBob69's Avatar
BillyBob69
I have seen many guys on here with E99s that have "upped" their injectors and done tunes without changing the PCM. Maybe I missed something and that is possible but I dont see where you would need to change the PCM. If you are getting tunes, (I am assuming a chip add-on), then the chip tells the PCM how to react to the new sticks.
EIther way...here is a link to a list of PCMS for different years and such. May help...
https://www.ford-trucks.com/forums/a...8&d=1352457829
Old Feb 15, 2013 | 02:12 PM
tappit01's Avatar
tappit01
well i found one with all the right #'s that will be compatible with the truck and tunes. $110.00 shipped , what a deal. thanks
Old Feb 15, 2013 | 04:28 PM
BillyBob69's Avatar
BillyBob69
Keep us updated how it goes when you get the new PCM and tunes in. Glad ya found one. Never say never!
Spool&Go
Oct 29, 2014 10:35 PM
broncxl302
Feb 13, 2012 11:55 AM
Visseroth
39
Jul 27, 2009 06:25 PM
sidwaz
Jan 28, 2009 09:25 AM
nhill2090
Jan 11, 2008 03:17 PM
