PCM Upgrade planning
Old May 30, 2009 | 04:30 AM
Visseroth's Avatar
Visseroth
Question PCM Upgrade planning
So I have been considering a PCM upgrade and have read a few posts on here in regards to it and on another forum
Basically if I was to upgrade my PCM on my E99 then I need to change my HPOP to a 17* and upgrade my turbo in order to take full advantage of what the PCM and my engine has to offer, correct?
Also, with a PCM upgrade is there a way to be rid of the AIH code that will be thrown since I don't have a AIH and don't want one?
Advantages of a new PCM are, cruise light works, quieter motor, more performance.....
Anything I'm missing?
Do I have to change my injectors as well with a PCM change?
Old May 30, 2009 | 05:19 AM
ron's power stroke's Avatar
ron's power stroke
you can do the PCM at any time..right now if you want..then do the other mods..as far as the AIH code..its just a soft code..no light..no way to use a resistor cause the early 99 dont even have the harness for the AIH..i been meaning to ask Jody if he can fix that in the PCM.. it doesnt hurt anything but your eyes when you see it pop up in testing..so i havent thought about It when i talk to him..
Old May 30, 2009 | 05:32 AM
Visseroth's Avatar
Visseroth
Well thanks, I was a little concerned about that because I was really wanting to get my cruise control light working
but yea, in regards to the AIH, I would really love to be able to get rid of that error because of one these days I'm going to install a on board PC and would like to have real time monitoring of my PCM w/logging and graphing.
I'm a tech junkie like that.
Old May 30, 2009 | 07:09 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Visseroth,
It doesn't matter if you upgrade your HPOP after installing a 99.5-01 PCM because the IPC, IPR, fuel rate, and pulse width maps in the programming are the same anyway. Ford never did program the PCM to use the entire 140cc of the AD injector over the 120cc AB injector of the early 99 trucks.
Old May 31, 2009 | 01:10 AM
Visseroth's Avatar
Visseroth
Ahh, very good. Well thanks for the info guys. I'll be looking at getting a replacement PCM for my truck as soon as possible.
Any recommendations on where to get one? Anyone have one laying around?
Old May 31, 2009 | 01:20 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Not to steer your away from doing it because it did help my shifting, but if you can't find one for $70-$80 I would wait. Jody currently has my early 99' XLE4 PCM and is doing testing and tuning with it. He seems to think that with some work there won't be any reason to do the swap. Just an FYI
Old May 31, 2009 | 01:29 AM
hucka1a's Avatar
hucka1a
Sweet, Jody told me that he was working on the XLE4.
Old May 31, 2009 | 02:36 AM
Visseroth's Avatar
Visseroth
Is this going to fix things like the cruise light not working?
Old May 31, 2009 | 02:41 AM
Riffraff Diesel
PREMIUM SPONSOR
No, I don't think that is something that can be changed. But mine still doesn't work even with the PMT1, maybe no bulb or maybe burn out. Just food for thought...
Old May 31, 2009 | 03:20 AM
Visseroth's Avatar
Visseroth
true true. Well I would like to try and get it to work. What other advantages are there to a PMT1?
Old May 31, 2009 | 03:46 PM
hucka1a's Avatar
hucka1a
The shifting is way better, my truck seems to start easier, acceleration is better, and the ebpv actually works in winter.
Old Jun 1, 2009 | 02:01 AM
Visseroth's Avatar
Visseroth
Shifting is only as good as I make it since I have a 6 speed but the starting and acceleration is what I'm looking for. What is EBPV?
Old Jun 1, 2009 | 02:13 AM
hucka1a's Avatar
hucka1a
Exhaust back pressure valve. It closes after cold start up during cold weather to help the engine warm up quicker.
Old Jun 1, 2009 | 02:35 AM
Visseroth's Avatar
Visseroth
ahh, very nice. Well none the less, going to get a PMT1 and update my lovely! Any ideas where to keep an eye for one?
Old Jun 1, 2009 | 08:22 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Since you have a 6-speed.....don't find a PMT1 unless you want the check engine light on all the time.
This might get confusing for you, but you'll now be on the lookout for anything with a "DPC-421" code on the tag instead of "DPC-422".
However, there will be much fewer benefits to the PCM swap now that we know you are shifting your own gears.
