Trim stud removal
Old Feb 15, 2013 | 08:40 AM
4x484150's Avatar
4x484150
Trim stud removal
Just a simple question. How would all of you get rid of the studs the hold on the body trim? Use a grinder, or some other way? Thanks!
Old Feb 15, 2013 | 08:50 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Grinder and glazing putty and primer...
Old Feb 16, 2013 | 03:33 PM
4x484150's Avatar
4x484150
Thanks Matt. Thats what I was thinking. Hopefully I can be careful enough to grind them flush, and not gouge out too much.
Old Feb 16, 2013 | 04:55 PM
2aul1642's Avatar
2aul1642
I used a grinder as well and just covered it up with some bondo since I'm repainting the truck anyways. Good luck!
Old Feb 16, 2013 | 07:11 PM
Hogtrapper's Avatar
Hogtrapper
I would use a grinder also but instead of a grinding disc/wheel I would use a flap disc. You will have to take your time so you don't tear up the disc but a flap disc leaves a much smoother finish.
Old Feb 16, 2013 | 07:39 PM
4x484150's Avatar
4x484150
Thanks for the suggestion Hogtrapper. What grit should I get?
Old Feb 16, 2013 | 09:02 PM
Hogtrapper's Avatar
Hogtrapper
Honestly I am not sure what all grits are offered in a flap disc but I would try to get something in the 125 grit range. I buy mine at the local welding supply store, they are a little more expensive but are a lot better quality than those purchased at a local "discount" store.
bamafarmboy
Sep 20, 2011 09:05 PM
JRon
Aug 19, 2010 08:07 PM
flysniper
Apr 8, 2009 09:36 AM
shameless
Mar 20, 2009 10:51 AM
fordxxx
Paint & Bodywork
Aug 31, 2004 11:51 AM
