1995 f-250 rear gas tank leak.
So the other day, i was taking apart the dash because the needle on the gears was broken, and i had to take the fuel tank switch off. when i tried to move the truck it wouldn't start so i took the switch and put it back on. and after i parked it, i could see gas dripping from the rear tank. and didn't know why. there was less than 1/4 of gas. after i switched to the front tank it stopped leaking. But the front tank doesn't work, most likely the pump is bad.
Why would it leak?
Did i ruin seals/pump?
Why would it leak?
Sounds like a problem unrelated to your working on the dash.
I would guess a leaking fuel line, possibly the return line connector is broken, but thats just a guess.
Ford rear tanks sometimes rust a hole in them, but its usually toward the top/middle of the tank, so if your fuel guage is working correctly thats probably not it.
Only way to know for sure is to drop the tank.
LutzBoy
03-17-2013 01:57 PM
Degreaser
02-29-2012 10:27 AM
stutterstan
01-08-2007 07:07 PM
mike L
07-19-2004 12:02 PM
