Update for Dash Boss, can't ...
Old Feb 14, 2013 | 04:39 PM
CR3999's Avatar
CR3999
Update for Dash Boss, can't seem to get the update to eject. Now the Dash Boss will not work at all. Anybody else have this problem?
Old Feb 14, 2013 | 06:32 PM
raptor131's Avatar
raptor131
Download the ZIP file (the above link) and extract it in a folder that is easy to find. You should end up with a file “Encrypted.dhx”. To update your gateway, perform the following:
  1. Plug your Gateway into an available USB port and verify the RED LED next to the USB plug lights up. You will also see a solid YELLOW LED and a blinking YELLOW LED which indicates the gateway is mounted on the USB connection.
  2. Verify the Gateway shows up as a removable drive and that the file “DELETEME.dhx” is on it
  3. DELETE the file “DELETEME.dhx”
  4. Simply drag and drop the firmware image (“Encrypted.dhx”) file ON TOP OF THE DashBoss™ removable drive icon.
  5. Wait for it to complete the copy
  6. EJECT the Gateway removable drive to be sure everything “flushes” to the gateway correctly.NOTE: We’ve seen a couple of instances of Windows “hanging on” to the drive for quite a while after you copy the file and giving an error that it can’t eject because it’s “still in use”. We’ve found that canceling the EJECT and just waiting (at times more than 2-5 minutes) and repeating the EJECT will clear it. We think it’s a matter of Windows 7 buffering the file and it needs to time out to flush it to the device. Sometimes you can ignore the error and just unplug the device, but if you find that the module is then not updated (shows the old firmware version in CONFIG on the app, you need to repeat the procedure and wait until it EJECTS properly).
  7. Now Unplug the Gateway
did you drag the base file to the device? does your pc recognize the device at all after the failed attempt?
IIRC, mine would not "eject" either, but I disconnected it with no issues
Old Feb 14, 2013 | 06:46 PM
CR3999's Avatar
CR3999
I took it to my neighbor and he did it for me. I wasn't opening the zip folder. These computers kick my behind
Old Feb 14, 2013 | 07:33 PM
raptor131's Avatar
raptor131
your neighbor messed up,I'm thinking
NukeUFO
2015 - 2020 F150
Jan 18, 2018 09:35 AM
srkr
6.7L Power Stroke Diesel
17
Nov 27, 2011 10:51 AM
omc124
Jan 30, 2011 01:43 PM
ducky702
2004 - 2008 F150
Mar 21, 2006 08:26 AM
Baja Daze
Jun 6, 2003 04:24 PM
