Fuel pump leak
Old Feb 14, 2013 | 02:54 PM
Dentside78's Avatar
Dentside78
Fuel pump leak
Hello friends I've got a problem with my pump leaking, specifically there is a tiny cylinder on top of the pump, one sides just open and leaks fuel out of it. Any reason for this? Can't take a picture right now, but hoping somebody here knows what I'm talking about. Thank you for your time.
Old Feb 14, 2013 | 05:29 PM
duallyhauler's Avatar
duallyhauler
The diaphram has a small rupture, go buy a new pump, their cheap.
Old Feb 14, 2013 | 05:42 PM
wyckedcombo17's Avatar
wyckedcombo17
X2, you need a new pump. That is the vent hole for the diaphragm, otherwise there would either be vacuum or pressure in the side of the diaphragm that has no gas in it.
Because it is torn, when the pump arm moves, the gas follows the path of least resistance and thats right out the little glory hole
Old Feb 14, 2013 | 05:58 PM
Dentside78's Avatar
Dentside78
Thank you both, I was guessing that but just wanted to be sure it wasn't something else entirely, looks like ill be in the snow changing the pump tommorow.
nothercrash
Dec 31, 2024 05:13 PM
cthn7d
Oct 9, 2019 09:38 AM
hunterguy86
Oct 9, 2006 03:50 AM
BltFordTough
Jan 17, 2006 07:02 AM
jcab
Jan 8, 2006 10:42 PM
