No start with key
Old Feb 14, 2013 | 10:49 AM
Country Traveler's Avatar
Country Traveler
No start with key
Anyone ever hear of this and what the cause is?
2000 V10 Excursion with stock alarm and remote start.
Intermittently, the truck does not start with the key in the ignition (the engine does not crank - there is nothing), but if I hit the button for the remote start, it starts right up every time. Then just drive away. Does it from time to time for about 3 or 4 starts in a row, then works fine for some time and then does it again. Any ideas?
Thanks
Old Feb 14, 2013 | 04:43 PM
greentree ford's Avatar
greentree ford
When the vehicle does not start, does the radio work?
Sounds like ignition wire is loose or frayed. Take off the plastic cover on the steering column and look for signs of wear.
Is there more then one key involved
Old Feb 17, 2013 | 05:18 AM
rangerboyxlt's Avatar
rangerboyxlt
Mine does this occasionally as well. Next time this happens try moving the shifter from park to drive and back to park, and try starting. If that does not give the desired result try moving from park to neutral and try starting. I believe mine does this due to the cable being out of adjustment.
Old Feb 20, 2013 | 10:07 AM
Country Traveler
Both good things to look at. Have to wait for it to do it again to see.
Also hearing it may be related to a failing fuel pump. If the pump does not get up the right pressure, a safety prevents it from starting. The remote start bypasses this safety feature and the truck starts but with weak fuel pressure. Anyone ever hear of this?
F350-6
Mar 9, 2026 10:19 AM
tfsiii
Jul 6, 2018 07:20 PM
HwyXingFrog
2004 - 2008 F150
Jul 23, 2012 11:35 PM
mauro12
Jul 21, 2011 09:17 PM
WebbySupercrew
1997 - 2003 F150
24
Nov 30, 2007 03:36 PM
