Cold no crank, no start
Old Feb 13, 2013 | 09:02 PM
TXAggies1's Avatar
TXAggies1
I have an 08 F150 5.4L with about 68k miles. When the temperature is 40 degrees or colder it will not crank. I had the same issue with my 2005. I can turn the key and nothing, lights, radio and everything work. The dash display has dashes all the across for the miles, temp and compass. I have found out that it doesn't matter if I leave the key forward in the run position or try to crank, it won't do anything. Battery is good and no problems with the truck. After the key is in and I give it anywhere from 15 to 60 seconds you can hear an electrical click real faintly and see the red security light come on and then the computer display comes on and then I can start with no problem? What could this be? My dealership has no clues and I can get it to act up because after I get it there it starts with no issue. The remotes work fine and this issue was why I got rid of my '05. Please help!!
Old Feb 14, 2013 | 09:57 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Perhaps you will find help faster up in the F150 forum for your truck. Here: 2004 - 2008 F150 - Ford Truck Enthusiasts Forums
Old Feb 14, 2013 | 11:40 AM
Franklin2's Avatar
Franklin2
Take it to the dealer and leave it overnight.
c502cid
Jan 18, 2026 09:54 AM
GonzoCSU
2009 - 2014 F150
32
Feb 9, 2018 06:28 PM
deputydog03
May 31, 2017 04:50 AM
TXAggies1
2004 - 2008 F150
Feb 14, 2013 08:59 PM
TXAggies1
Modular V8 (4.6L, 5.4L)
Feb 14, 2013 01:01 PM
