trouble codes "deq test report"
Old Feb 13, 2013 | 08:06 PM
wizzy214's Avatar
wizzy214
so went to deq to renew tags and they found some stuff.
how do i fix these codes and the told me i need to drive 100+ miles to clear them from ecu. they also told me my check engine light is on but not on due to a burnt out bulb. and there were like five guys looking at my van cuz it has about 15 led strips in the back to light it up.
P1406-
P0402-
P0442-
i have a obd-2 code reader buts its not working right now.
just looking some help,
thanks
Old Feb 13, 2013 | 09:31 PM
95e150CW's Avatar
95e150CW
0422 is Evaporative Recovery System Small leak, could be a leak somewhere in the evap system (very hard to find small ones) or you just have a ****ty/aftermarket/locking gascap. Make sure the gascap seals nice and tight, and that the fuel filler hose isnt damaged. If that doesn't clear the code then you will have to start exploring the EVAP system. On ford vans, the EVAP system is huge. Its all around in the engine compartment, and has a series of lines going to your fuel tank. Small splits can be a real bear to track down without a smoke machine (and even with a smoke machine sometimes...)
1406 and 0406 are for the EGR system. Double check the EGR valve is clean and works okay, then replace the DPFE if that doesn't make the issue go away.
Honestly its almost always the DPFE when you get 1406 and 0406 together, and the aftermarket parts are crap. Go to Ford and get theirs, as they designed a new one to solve the failure issue.
Its pretty rare for the CEL to burn out, and that also causes a fail at a LOT of testing centers. Pull the cluster and replace the burnt bulb (which I suspect is probably honestly missing or disconnected).
MikeB 88
1983 - 2012 Ranger & B-Series
Jun 10, 2010 08:25 AM
itsjustdan26
Electrical Systems/Wiring
Oct 6, 2009 06:08 PM
n5926g
1997 - 2003 F150
Oct 25, 2008 10:12 PM
deezoman
Aug 16, 2007 06:51 AM
amexjoe
General Automotive Discussion
Oct 6, 2004 03:03 PM
