Sponsored by: Auxito
Code 0455
Old Oct 25, 2008 | 02:01 PM
n5926g's Avatar
n5926g
Code 0455
Hi Guys,
I just ran the OBDII on my 97 F-150...I got three codes,one was 0401...EGR Insufficient flow,0420....Catylist system efficiency below threshold,and then the 0455...Evap Emission control system leak detected(Gross leak)....
First of all,these codes were NOT in the Ford section of the OBDII book,rather the generic....The EGR code Im suspecting is a "cleaning" issue,the Converter code is being addressed,as new converters(and upstream 02 sensors) are on the way...The baffling code is the 0455,Ive looked all over the truck,inspected vac lines,hoses etc,and cant "see" anything out of place.
The questions I have are as follows:
Are these "Generic" codes applicable to the truck(Ford)
Is there any sensor(or component) that I should suspect(inspect) to fix the Evap Emissions Gross leak detected code?
Thanks!
Alan
1997 F-150XL,4.2 v-6,automatic LWB
Old Oct 25, 2008 | 09:20 PM
JasonCorvallis's Avatar
JasonCorvallis
evap i think is the evaporative emmisions for the fuel tank there is a evap can and ect back by the tank that can leak or get clogged. there is an evap test on the ids for system checks.
Old Oct 25, 2008 | 09:38 PM
EdwrdEdmnds's Avatar
EdwrdEdmnds
the 0401 is the dpfe sensor out of range dpfe has a reference voltage of 5 volts anything lower or higher and it needs to be changed. 0455 gross leak, check fuel
cap and or replace it for starters, just to try something simple, other than that it could
be anything related to fuel vapor leak. 0420 don't have any information on that particular code, just rattling things off the top of my head.hope it helps
Old Oct 25, 2008 | 10:12 PM
projectSHO89's Avatar
projectSHO89
All three "generic" codes are used on Fords.
To see the full complement of codes, go to www.motorcraftservice.com and check out the OBDII manuals available (free downloads) under the Tech Resources tab.
Steve
mkotalik
1997 - 2003 F150
Sep 26, 2016 11:42 AM
mfp4073
1983 - 2012 Ranger & B-Series
May 7, 2015 10:25 PM
zurgur
Escape & Escape Hybrid
Feb 9, 2012 11:52 AM
n5926g
1997 - 2003 F150
Feb 7, 2009 08:15 AM
thelemur
May 4, 2004 07:34 AM
