P0401 & P0455 codes
Old Jun 8, 2010 | 08:51 AM
MikeB 88's Avatar
MikeB 88
P0401 & P0455 codes
My Ranger is a 2000 model with the 2.5L and 5 speed transmission with 146,000 on the odometer. The other night I was headed to work, cruising along at a steady 65 when the CEL came on. Dropped by my local O'Reilly Auto Parts on the way home to and found both P0401 and P0455 codes were thrown.
Looking at the Tech section, the 401 has to do with the EGR system. Can anyone tell me where the EGR valve is on the 2.5L. I also understand the 455 code has to do with the EVAP system. Can/are these systems related? Can anyone give me some hints/tips to troubleshoot the EVAP system.
I also have an aftermarket locking gas cap installed. Been on there since last year when gas prices were sky high. It's also been 120 miles since the last fuel up.
Thanks,
Old Jun 8, 2010 | 09:22 AM
shad44's Avatar
shad44
My 01 4.0 has had the 401 code twice in the last 8 months, both times its been the pressure feedback switch, cheap easy fix, manual says the evap 455 code is a leak so I would find the canister and check all the lines, as far as I can tell the egr and evap systems are separate.
Old Jun 8, 2010 | 02:46 PM
powersmoked's Avatar
powersmoked
I don't know a lot about this but I will tell you the few things i do know. the p0455 is for a large leak in the evap system. aka "the gas cap" code. The egr valve rarely fails it can get dirty and you should clean it out. You could have a cracked or disconnected hose. the dpfe is what usually fails in the EGR system
Old Jun 8, 2010 | 03:12 PM
g_k50's Avatar
g_k50
Replace defective aftermarket locking gas cap with orginal.
Old Jun 8, 2010 | 06:57 PM
shad44's Avatar
shad44
Good to know that 455 is usually the gas cap...I'll have to remember that!
Old Jun 8, 2010 | 08:59 PM
MikeB 88's Avatar
MikeB 88
I put the original cap tonight. I hope that the 455 code goes away in a couple days. I'll probably have to wait until to look at the EGR system.
Old Jun 10, 2010 | 08:25 AM
MikeB 88's Avatar
MikeB 88
I'm going to dig into my EGR system this weekend. I was on Advance Auto Parts site to look up parts. Is there a way to check the feedback sensor EGR Pressure Feedback Sensor by BWD - Part EGR155 - Advance Auto Parts
or control sensor EGR Control Solenoid by BWD - Part EGR3001 - Advance Auto Parts
Most likely if I take the EGR valve off to clean it and my engine has 146,600 miles on it, I'll put a new one on.
Jon Downing
1997 - 2003 F150
Apr 21, 2017 06:21 PM
FFJohn
Dec 11, 2016 11:56 AM
Ford'05HG
Oct 26, 2016 09:10 AM
rogerranger2122
Oct 3, 2016 09:09 AM
Piratejonh
Oct 21, 2012 09:07 PM
