Sponsored by: Auxito
1997 4.6 help!
Old Feb 13, 2013 | 02:38 PM
PSD2005's Avatar
PSD2005
1997 4.6 help!
The wife was about to come home from work this afternoon! She said she started it up and it ran fine, but when she put it in reverse it almost died! Then she said she put it in to park gas on it a little put it back in reverse! Now she did say she did it fast the second time! It made it home, when I got home I started it up and put it in reverse and in drive and it did fine! These are the codes I pull up P0401 and a P0171! Any idea?
Old Feb 13, 2013 | 07:11 PM
pdqford's Avatar
pdqford
The P0401 is insuffiecient flow in the ERG system. Make sure the hoses are attached to the DPFE and that any condensation accumalated in it has not frozen if you are in a COLD location.
The P0171 indicates that the PCM has driven the bank 1 fuel injectors full rich and the HO2S says the bank is still too lean. More than likely you have a vacuum leak. Check the infamous PCV elbow in the PCV line at the back of the intake manifold.
Good luck.
Andrew121
2004 - 2008 F150
Mar 21, 2016 08:11 AM
Shane Dulemba
1997 - 2003 F150
Sep 21, 2015 06:55 AM
Robs06SuperDuty
Jul 10, 2009 04:15 PM
muckypaws
1978 - 1996 Big Bronco
Dec 28, 2005 06:02 AM
