should i replace water pump
Old Feb 12, 2013 | 11:08 PM
hedhntr's Avatar
hedhntr
120000 on stock pump. Not leaking but has me a little worried it's gonna leave me stranded.I want to change to eLC but hate to and lose all that spendy new coolant if the pump goes
Old Feb 12, 2013 | 11:48 PM
Kdr358's Avatar
Kdr358
I would replace it, they are cheap enough and you can also do the thermostat at the same time, then you know where you stand. Its a 2 hour job at most, Clay at riffraff has everything listed, Motorcraft thermostat, lower inlet Oring and the gasket is included with the pump. They are OEM International pumps. Aftermarket t-stats have been known to cause issues.
Riffraff Diesel: OEM Powerstroke Water Pump
Old Feb 13, 2013 | 08:09 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
That's a good idea to do it all at once. Spray those block plugs several times with PB days ahead of time. Really helps out.
Good luck!
Old Feb 13, 2013 | 08:17 AM
Brother Les's Avatar
Brother Les
Fix something that anit broke..... I wish I had that much time on my hands and money to burn...
Old Feb 13, 2013 | 09:11 AM
Whitey Ford
Replace the hoses while you at it. The aluminum thermostat housing is also a good idea.
Good luck!
Old Feb 13, 2013 | 09:18 AM
Brother Les
Hoses and serpentine belt I can see.....
Old Feb 13, 2013 | 09:21 AM
SkySkiJason's Avatar
SkySkiJason
Amen!!
Catastrophic pump failures are RARE. It will begin to drip out of the weep hole - giving you plenty of time to get a waterpump ordered and installed.
This is another cool option though, if you indeed have $$$ to burn! Built-in coolant filter.
International T444E Water Pump Sales, 1831676C92, 1889249C91
Int'l part # 1831676 C92
Old Feb 13, 2013 | 09:42 AM
Whitey Ford
You could sure flush the system out good with the pump, plugs & thermostat out. For an extra $100 for the pump and a couple extra hours of time, you should get another 10 years of trouble free coolant system use. A win win for the motor & owner!
Trouble-free use is the reason people burn big money on transmissions isn't it?
Old Feb 13, 2013 | 10:49 AM
Kdr358's Avatar
Kdr358
Spend the money now if you can like I did, new hoses, t stat and pump. I like the piece of mind of not having to deal with little issues. We need to realize that the newest 7.3 is now hitting 10 years old. Bolt ons will start to show their age. To each is own but I like only doing jobs once. I did mine because it was used, and I didn't know if it was original or not, it's also a good indicator of how well the cooling system was maintained. If you look at the area behind the pump and see no pitting its usually a good sign!
'74 Ford 250 CS
25
Oct 1, 2018 01:25 PM
glovemeister
Feb 23, 2013 09:22 AM
jchosler
15
May 1, 2010 05:44 PM
Benjoman
Nov 23, 2009 07:46 PM
lowrango
26
Mar 20, 2007 09:03 PM
