half my dash is out?
Old Feb 12, 2013 | 11:38 AM
DikHedECV3's Avatar
DikHedECV3
From day one of having better up her dash hasn't been working right. The gas gauge and speedo are working fine. The temp gauge moves a little. I could be driving for hours and the needle will just past the cold and into the box between cold and hot. Also at night the dash lights don't come on. Anyone have this issue or know how to fix it? Kinda sucks at night not knowing if your speeding. Thanks
Old Feb 12, 2013 | 11:52 AM
bigdan1979f-250's Avatar
bigdan1979f-250
Have you checked any fuses to see if they blew? Might be a bad printed circuit, doubt it would be a blown bulb if half of them don't come on....
Old Feb 12, 2013 | 11:56 AM
DikHedECV3's Avatar
DikHedECV3
Ya. We checked all of them and basically replaced any that looked slightly worn. All the fuses are new. That's why we are stumped
Old Feb 12, 2013 | 12:08 PM
bucks77ford's Avatar
bucks77ford
The factory temp gauges are pretty inaccurate and what yours is doing is common. The temp sending unit could be bad, but I'd get a decent temp gauge to see what temp you are actually running.
A common problem with dash lights is the printed circuit gets corroded and doesn't make good contact with the bulb sockets. Otherwise, first check to make sure the light switch hasn't been turned clockwise to dim the dash. That can easily be forgotten about.
Old Feb 12, 2013 | 12:12 PM
DikHedECV3's Avatar
DikHedECV3
Sounds good. I will check that later. Thanks
Old Feb 12, 2013 | 02:25 PM
fmc400's Avatar
fmc400
MSEE
If your gas gauge is fine, the instrument cluster voltage regulator is also fine, and the issue with the temperature gauge is most likely the sending unit itself. But as was said above, it should not be relied upon heavily in the first place.
Dash lights get brought up at least 2 to 3 times a week - to save time, I am confident that if you search "dash lights" in this forum, you will find several detailed write-ups from both myself and others regarding potential problems.
Old Feb 12, 2013 | 03:51 PM
earthquake68's Avatar
earthquake68
You DO realize there's only TWO dash lights that back light all three sections of the cluster, right? If it's half out, that means you have A bulb out. The rest of the bulbs back there are for indicator or idiot lights. Clean the contacts on the circuit board and the tabs on the sockets. Then carefully bend the tabs on the socket out a little and even more carefully put the sockets back in the plastic dash. They should work.
Old Feb 12, 2013 | 04:58 PM
fmc400's Avatar
fmc400
MSEE
The thread is titled "half my dash is out" - that seems to mean a combination of lights and gauges are non-functional based on his list of issues. I interpreted his note below to mean all of the dash lights are out (indicating a problem upstream).
I guess the OP should clarify.
Old Feb 12, 2013 | 06:20 PM
ashbleep's Avatar
ashbleep
what do you mean by "better up her dash" ???
Did you change the cluster?
white Buffalo
Dec 7, 2014 12:58 AM
rattleNsmoke
Jan 22, 2014 12:11 PM
hdman6
Apr 22, 2012 03:33 PM
f350duallyguy
Sep 24, 2007 05:11 PM
Ultraboy
Dec 11, 2005 02:04 AM
