92 exp temp guage going nuts...help
Old Sep 24, 2007 | 08:58 AM
f350duallyguy's Avatar
f350duallyguy
Question 92 exp temp guage going nuts...help
I have a 92 explorer with the 4.0 the temp guage goes up to hot then drops back down while driving...already replaced the radiator,thermostat,and temp sending switch. could it be a bad guage in the dash?any help would be apriciated,I'm not sure what do do next
Old Sep 24, 2007 | 11:09 AM
mrshorty's Avatar
mrshorty
Yes, it could be a bad gauge or bad wiring between the sender and the dash or something like that.
When I had similar behavior on y '92, I backprobed a voltmeter into the computer's ECT, which is independent of the dash gauge sender. If the ECT behaves like the dash gauge, then the dash gauge is probably ok. If the ECT shows something different, then the dash gauge is probably having a problem.
Old Sep 24, 2007 | 11:16 AM
f350duallyguy
I don't want to sound like an idiot ...but the ECT( engine coolant Temp sensor) is that different from the temp sending switch that I already replaced
Old Sep 24, 2007 | 02:08 PM
mrshorty's Avatar
mrshorty
If your '92 is like my '92, you have two temperature sensors. One feeds the dash gauge (single wire sensor), and the other goes to the computer (two wire sensor), so they are different.
Old Sep 24, 2007 | 02:27 PM
f350duallyguy
I'll look for the two wire sensor,the single wire is the one I replaced, is it possible that the one going to the computer is messing the second one up
Old Sep 24, 2007 | 05:11 PM
mrshorty's Avatar
mrshorty
It's hard for me to say that it is absolutely impossible, but I would say that it is highly unlikely that the two temperature sensors are interfering with each other. The idea is to simply compare the outputs of the two thermometers and see if they parallel each other (indicates that the dash gauge is probably right) or if they show something different (indicates that the dash gauge has a problem).
