302 vs. 351
Old Feb 11, 2013 | 08:00 PM
vegasford's Avatar
vegasford
302 vs. 351
I'm building a prerunner using a courier and can't decided which engine to use it's between the 302 or 351w. I'm not trying to get 500hp or any thing like that. I'm just looking to have plenty of power and reliability. also how hard is it to change an efi back to carborated?
Old Feb 11, 2013 | 08:05 PM
Conanski's Avatar
Conanski
Define plenty of power.
If you have the room a 351 wins every time all else being equal. EFI to carb is simply a matter of changing the induction, ignition, and fuel systems.
Old Feb 11, 2013 | 10:15 PM
vegasford's Avatar
vegasford
around 350rwhp is what I'd be fine with
Old Feb 12, 2013 | 12:07 AM
vegasford's Avatar
vegasford
and what manual tranny would i want to use? i'm using a 9' solid rear end
Old Feb 12, 2013 | 09:16 AM
Conanski's Avatar
Conanski
It easier to get 400 fwHP from a 351 (less rpm) and it's therefore more reliable, this will require a complete aftermarket topend of course. Lots of trans options, T18 and T19 4 speeds or a ZF 5speed though I don't see you needing overdrive.
Old Feb 12, 2013 | 11:46 AM
vegasford's Avatar
vegasford
what's the biggest difference between the t18 and t19? and they'll both work for a 2wd right?
Old Feb 13, 2013 | 04:20 PM
Alvin in AZ's Avatar
Alvin in AZ
They are basically the same thing. :)
http://www.novak-adapt.com/images/gr...ecs_gasket.gif
Back off that URL off to .com/ and check it out too. :)
"Google is your friend" -They
Alvin in AZ
'75 F150 360FE, T18 Under the skin it's really just a Bump-Side ;)
lariat87
32
Jan 26, 2007 05:57 PM
Rascal2k
1978 - 1996 Big Bronco
Nov 25, 2003 03:28 PM
Racerdave
Jul 3, 2003 03:44 PM
bud 321
Oct 29, 2002 12:40 AM
Falcon90
Jun 2, 2002 04:11 PM
