400 rebuild
Old Feb 11, 2013 | 01:21 PM
shawn11762010's Avatar
shawn11762010
400 rebuild
I am about to start rebuilding my 78 400 motor. Does anyone know were to find some good articles on adding some more horsepower. Thank you.
Old Feb 11, 2013 | 01:41 PM
mark a.'s Avatar
mark a.
Right here, ask away.
Old Feb 11, 2013 | 02:02 PM
ctubutis's Avatar
ctubutis
Did you look through the Sticky at the top of this forum?
Old Feb 12, 2013 | 08:48 PM
79silverstreak's Avatar
79silverstreak
This s what I did....
-Howard's hydraulic roller cam in. 217@ .050", .571"/ ex. 225@.050" .576"
-Linked hydraulic roller lifters
-Hasting's moly coated to ring set
-King bearings
-Melling oil pump
-All Felpro gaskets throughout
-Comp dual valve springs matched to my cam (part#924)
-Positive valve seals
-Comp cams 8.903" Hardened push-rod, coupled with .030" shims gave me near perfect wear pattern and 1/4 reload(Howard's recommend)
-New factory replacement dampener, forget the brand
-NGK G series iridium plugs
-Flow-tech ceramic coated headers, 1.75" primaries, 3.0" collectors
-KB2347 hyper pistons .040" over
-ARP main, rod and head bolts
-2.05" & 1.65" SS valves
-1.73 Scorpion pedestal mount roller rockers
-.010/.010 stock crank and rebuilt rods(balanced)
-Double roller timing set, Comp
-Flowkooler aluminum water pump
-MSD pro billet distributor
-Moroso 8.0mm wires
-Weiand Action plus 4v manifold
-Qft 650 annular mechanical secondary SS series+ 1" spacer
This is what I got....
With initial timing at 16 degrees and total at 32, coming in fully around 3500rpm, with an air fuel ratio of 13.46 (peak torque)
500.4ftlbs @3100 rpm
383.2 hp @4950rpm.
Edit: Oh, and with factory open chamber heads
Old Feb 28, 2013 | 01:42 AM
privateer, eh's Avatar
privateer, eh
One of these days I'm going to learn to read the read first threads, but I don't want to put the SilverStreak out of business. Conumdrum time. What would ctubutis do??
Help, program not responding.
Old Mar 4, 2013 | 08:36 PM
79silverstreak
Ya can't pass up a chance to brag....
Old Mar 5, 2013 | 12:49 AM
privateer, eh
Whatevers on the bottom, your the tops
mustange70
Jun 19, 2009 03:15 PM
powerstation
20
Oct 15, 2003 12:16 AM
77f-150bigblock400
May 23, 2003 10:34 PM
Mil1ion
May 24, 2002 06:09 PM
Franklin2
Dec 31, 2001 10:03 PM
