shift indicator
Old Feb 10, 2013 | 08:59 AM
Leeboy1962's Avatar
Leeboy1962
shift indicator
On my 1981 F-150 with AOD tranmission,the shift indicator cable is broke.Does anyone know where to get a replacement cable/or maybe another way to fix it?Thanks in advance
Old Feb 10, 2013 | 10:08 AM
Old Hickory's Avatar
Old Hickory
I'm not sure if there is any source for just the cable. I had the same problem as you do with my 1981 F100 with an AOD. I ordered a new shift indicator with cable from LMC truck. The only issue is that they only have the C4/C6 indicator, but I found it easy to fit the new cable from the new indicator to my existing AOD indicator and it works perfectly. The new indicator from LMC is also a genuine Ford part.
Old Feb 10, 2013 | 12:24 PM
Leeboy1962's Avatar
Leeboy1962
Thank you for the tip,I got another tip that said that NOS Parts Source Olathe KS 913 220 5746 has the cable.I haven't had
a chance to call them yet,but I will check out both sources.Thanks again
Precisionshooting
Mar 19, 2025 09:21 PM
fatfenders56
Jan 24, 2013 09:20 PM
blueovalboy86
Jun 7, 2005 09:18 AM
Wheels6293
Jul 7, 2003 12:19 AM
