2003 Ford Explorer transmission problems
Old Feb 10, 2013 | 02:11 AM
dmal's Avatar
dmal
4wd Low
My Explorer started to shift slow from 1st to 2nd. I ordered servos hoping that is the problem. While I waited for parts,I allowed my wife to continue to drive it and it unexpectedly stopped working completely after sitting all day...no forward...no reverse. I plan to remove the pan next week. My question is, what are the likely causes for a transmission to completely fail while sitting parked? What should I look for first? What should I test? Are there any helpful threads that I should read?
Old Feb 10, 2013 | 02:06 PM
KhanTyranitar's Avatar
KhanTyranitar
Why didn't you start with changing the fluid and filter?
Low fluid can cause slow shifting and delayed or no engagement into 1st or reverse.
Old Feb 10, 2013 | 02:58 PM
dmal's Avatar
dmal
4wd Low
I started with adding fluid. It did not appear to be low. I ordered a filter and gasket, but it stopped moving before I received my parts. My hope is to only drop the pan once...wish me luck.
tg3226
Feb 23, 2017 10:05 PM
dgd50
Aug 1, 2014 07:10 AM
dledm
Aug 28, 2011 09:45 PM
highoctane74
May 24, 2009 12:55 PM
"Eddie_B_Bauer"
Nov 23, 2003 11:17 AM
