1993 vss help
Old Feb 9, 2013 | 03:49 PM
flaboy1979's Avatar
flaboy1979
1993 vss help
i found a 1993 e-350 with 460 and c6 with 22000 miles was a winabago now just cab chassie.i can get it for 1000$ does it shift off of a vss and if so what is the easyest way to make it work.and will i have to have the speedomiter installed keep in mind this is a off road mud truck yes it is two wheel drive but i already have a divorced 205 so im good with that thank you
Old Feb 9, 2013 | 05:57 PM
danr1's Avatar
danr1
C6 is vacuum modulated, no VSS/speedo required.
Old Feb 10, 2013 | 09:19 AM
flaboy1979's Avatar
flaboy1979
it is not a c6 it has a od off button on the shifter
Old Feb 10, 2013 | 09:31 AM
jrwhitmire's Avatar
jrwhitmire
Gonna need the VSS operating with an electrically controlled Trans. Just curious, if it's an E-cab and was a Winnebago, isn't the back of the cab open?
Old Feb 10, 2013 | 09:37 AM
flaboy1979's Avatar
flaboy1979
yes the back is open im going to rob all the drive train and scrap it will i need to install the speed O
Old Feb 10, 2013 | 09:45 AM
jrwhitmire's Avatar
jrwhitmire
No, the PCM (powertrain control module) needs the reference from the VSS, not the speedo. Might be easier to use a C6, carb and DSII dist. rather than all the wiring you'll have to do, unless you have a similar year truck you're putting everything into.
Old Feb 10, 2013 | 09:56 AM
flaboy1979's Avatar
flaboy1979
i want the efi the reason i ask about the speed o is i had 96 f150 speedo went out and trans would not shift till i put a new one in
Old Feb 10, 2013 | 10:33 AM
jrwhitmire's Avatar
jrwhitmire
A '96 would be OBDII, maybe different, '93 is OBDI, I'm pretty sure speedo is unnecessary for trans operation, maybe someone else will chime in, but if the VSS signal did go to speedo, then to the transmission harness connector, I would think you could simply bypass the speedo.
Old Feb 10, 2013 | 11:33 AM
Phy's Avatar
Phy
The PCM for the E4OD trans needs a road speed signal from the PSOM. The PSOM gets it's axle speed signal from the VSS, and converts that to road speed for the PCM.
seajr1978
18
Apr 1, 2013 06:52 AM
meltmtl
May 21, 2011 01:55 AM
limptera13
Aug 27, 2010 07:12 PM
oldiron
Feb 13, 2010 10:41 PM
showcow
13
Feb 27, 2006 08:32 PM
