auto lock hub issue
Old Feb 9, 2013 | 12:41 PM
KRH1326's Avatar
KRH1326
auto lock hub issue
Hi All...
I have a 1999 Ranger, with the auto locking front hubs. This nor'easter hit us with 18" and I needed the 4WD.
The transfer case does its thing ok, but the hubs will not lock...
I checked both sides, and have good vacum, to each hub. Just for the heck of it, I stuck a hose on the passenger hub connection... blew and sucked (ha ha ha) by mouth. Could feel resistance and hear the hub trying to lock and disengage. Seems to be acting right. I tried it on the drivers side and got no resistance, free moving air, nothing else.
I assume the drivers side hub is malfunctioning. Broken diaphragm? Bad seal ? What can it be, my chilton and haynes books are useless with the 4WD hub issues....
If one hub ( drivers side ) fails to engage, would that prevent the other ( passenger ) from locking? sorta like posi verse limited slip rear?
Is there a way I can force the fronts to lock, until my local roads are more managable, and can make proper repairs?
Thank you...
Ken
Old Feb 11, 2013 | 06:15 PM
Rockledge's Avatar
Rockledge
No, a single PVH hub can engage even if the other side won't.
You can either pickup some AVM manual lockers to swap in, or do THIS.
If you want to do some troubleshooting first, check out Ranger PVH Diagnostics.
adjc
Oct 27, 2018 07:49 AM
wapitiguide
Nov 27, 2012 07:38 PM
getnbz
Mar 6, 2008 03:58 PM
NorthAz
Dec 8, 2007 05:28 PM
camsamjam
Mar 21, 2006 04:51 PM
