this is the second time its happened i just fond that the hub locked went from free to lock by itself. it was the same side both times what is going on here do i got ghosts or what lol
There's a fair chance you have some debris caught in there that's causing it to rotate when you drive, I found a piece of gravel jammed up in one of mine that caused it to do the same thing. Might be worth your time to pull the front off and check for junk in there. Or slap the joker that's messing with your hubs
