1994 E150 Door Locks do not work
Old Feb 9, 2013 | 11:53 AM
roger48624's Avatar
roger48624
Hi Guys,
I have a 1994 conversion van and the door locks do not work at all. The actual cyclinders will work if you hook 12 volts to them directly. Checked all fuses everything seems fine there. There is no power at the switches. Is there a Module or relay for the door lock system? If so , where is it located and does anyone know the part number? Thanks in advance for any help you can offer.
Old Feb 9, 2013 | 12:05 PM
95e150CW's Avatar
95e150CW
If the van was built with factory door locks, the locks are controlled by a module behind the driver seat, inside the wall. You will have to remove the trim to get to it.
If the van was given an aftermarket power lock system, you will have to hunt for it on your own.
Old Feb 10, 2013 | 07:09 AM
JWA's Avatar
JWA
In '94 its unlikely the Remote Keyless Entry Module (RKE) was used---don't think they came about until '02 or so? My '97 and '00 didn't have that module but the '03 does.
On the '94 factory PDL's were simply wired into the master control switch on the drivers side front door.
Of course conversion vans were a whole other story----best of luck there!
Sorry if I'm mistaken about this.
Old Feb 10, 2013 | 10:53 AM
roger48624's Avatar
roger48624
Thanks for the info.
Old Feb 10, 2013 | 02:28 PM
95e150CW's Avatar
95e150CW
My 95 Wagon has factory RKE, factory power windows, and a factory alarm with starter disable (called the 'security personality module' in some documentation, or anti-theft in others). Ford also granted it an airbag, cruise control, and 4 wheel ABS.
TSB 93-24-12 even gives a few details about the system used on pre 95 systems.
KB Results
Old Feb 10, 2013 | 03:15 PM
95e150CW's Avatar
95e150CW
I had to hunt around for my service CD, but could only fine my 92 disc. 92 vans should be substantially similar to your 94, as this service guide appears similar to my 95.
The odds of you finding this information legitimately for sale from a Ford source are pretty slim, so here is the diagnostic routine for a 92's power lock system.
DIAGNOSTICS_POWER_LOCKS_92.pdf
TESTING_DOOR_LOCK_92.pdf
(The red DOWNLOAD link with the green arrow point downwards, on the bottom left corner of the screen.)
Old Feb 11, 2013 | 04:45 AM
JWA's Avatar
JWA
KB Results
Learn something new every day---thanks 95e150!
Mach5
Jul 5, 2018 07:35 PM
66 Evan
Jun 29, 2017 08:02 PM
007jvg
Dec 12, 2015 04:42 AM
tored1971
Jul 7, 2013 07:20 AM
RNUTTER
1997 - 2003 F150
Sep 7, 2003 03:14 AM
