1999 E-350 Door Lock Gremlins
Old Jul 1, 2018 | 02:01 PM
Mach5's Avatar
Mach5
I've been searching for a definitive test and comment thread on the power locks. I've seen some for the Expeditions and Explorers, but not so much for the van. I'm not sure to what extent they differ, but since it seems like a lot of the van stuff is "van unique" I thought I'd ask to see what I get for a response. So, here is my situation:
1999 E-350 XLT Club Wagon RB v10. When I got it the door locks would work intermittently with the remote, but not with the switches in the doors. Now they don't work with either. The remote does still operate and I can hear noise in the doors like the locks are attempting to work, but nothing happens. I pulled the lock from the rear door because it wasn't working at all. I attempted to do the foil repair but that didn't seem to help, so it seems I have some other problem. I haven't yet tested the switches, but suspect one or more of them is kaput. Meanwhile, as I'm driving down the road, every now and then the door locks will mysteriously lock or unlock (generally all of the front doors and side door). There doesn't seem to be any rhyme or reason to this happening (i.e, going over a bump). I live in Phoenix so the weather is generally dry.
Any thoughts? Directions for testing and eliminating variables?
Thanks.
Old Jul 1, 2018 | 05:32 PM
CarpetusMaximus313's Avatar
CarpetusMaximus313
It was my back door lock that affected my whole system. Because of moisture getting on the contacts.
cleaned the contacts with sandpaper and made sure the rear switch was making good connection. Now all my locks work as they should. By taking the back one out I think is where your problem lies. Good luck the doors are a pain in the *** but hey, the van is worth it.
Old Jul 1, 2018 | 07:37 PM
Mach5's Avatar
Mach5
All the problems I described were before I took out and attempted to repair the rear door lock. But cleaning contacts makes sense from a switch operating perspective. I don't understand how bad contacts could cause intermittent locking and unlocking when none of the switches are being pressed though. Can you elaborate on that. Thanks.
Old Jul 1, 2018 | 09:47 PM
Ryan Greene's Avatar
Ryan Greene
I was reading up to see if my 98 even has keyless entry, since it does have power locks, and read a thread about having weird things happening similar to your description. That guy pulled his RKE module out and found a broken wire on the plug for the box. The RKE is next to the drivers seat but I’m not sure if it is in the c pillar or behind it, or I read it’s behind the kick panel. I’m going to do some digging for mine so if I find it I’ll report specific location. Good luck
Old Jul 3, 2018 | 05:45 AM
Rick1025's Avatar
Rick1025
My 2002 did the intermittent lock/unlock thing. I took out the module and found the previous owners kids had spilled sugary drinks on it and it was all gummed up . I rinsed it off and let it dry and reinstalled it. It has worked perfectly for years.
Old Jul 3, 2018 | 09:59 AM
BigBlue 94's Avatar
BigBlue 94
My 99 had a similar issue. No RKE on mine. I replaced the blown fuse, and the locks would sometimes work. I checked the rear door switch, and it was busted. I could get the whole system to work if i held that broken switch just right. That switch must be operable for the whole system to work. You also could remove it and connect a couple of the wires to fool the system.
Here's the switch I bought from ford. Everything works as it should now. Was $54 with tax. LKQ had one in the whole country, and wasn't available yet. Used, it was $35.
Old Jul 5, 2018 | 07:35 PM
EmilBarnabas's Avatar
EmilBarnabas
Check this thread. https://www.ford-trucks.com/forums/8...entry-fix.html
Haleyinthevalley
Jan 18, 2024 11:30 AM
dukefan70
Sep 3, 2023 09:57 AM
Mach5
Nov 20, 2019 03:35 AM
jamnjm
Oct 10, 2016 01:34 PM
007jvg
Dec 12, 2015 04:42 AM
