Electrical Question
Old 02-08-2013, 06:44 PM
FlagshipOne's Avatar
FlagshipOne
FlagshipOne is offline
Electrical Question
so my windshield washer sprayers stopped working. I originally thought it was the pump in the reservoir so I replaced it. still not working. then I entertained the thought that it might be the electrical connection attached to the end of the pump. The question is: how do I test it and if that is it how do I replace it?
1992 F250 w/ 7.5L
Old 02-08-2013, 07:01 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Use a volt meter or test light at the pump's connections to see if you have power there when you push the button in the cab.
Have you checked your fuses?
Old 02-08-2013, 11:51 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I had the same thing you have at one point.
The wires at the connector were broken.
You can test with a needle point probe by poking through the insulation.
I had to cut back a bit as the wires were all black and corroded inside.
I was able to get a new connector at Carquest.
Old 02-11-2013, 09:29 AM
FlagshipOne
it was the fuse. thanks everyone!
SUPERDUTY_08
10-16-2022 08:10 AM
pekkah
06-02-2008 04:48 AM
Wakeboarder141
1978 - 1996 Big Bronco
12-05-2004 02:20 PM
rkd1956
12-28-2003 11:34 AM
acerockola77
05-04-2003 01:52 PM
Quick Reply: Electrical Question
