Coolant Flush Question
Old Feb 4, 2013 | 01:48 PM
FlagshipOne's Avatar
FlagshipOne
Guys
I just bought a 1992 Ford F250 4x4 w. 7.5L (460) gas engine. I am getting ready to do a tune-up and was curious as to the what and why of flushing and replacing the coolant. Can someone point me to the exact process, etc?
Old Feb 4, 2013 | 05:26 PM
lv2race's Avatar
lv2race
Coolant, like automatic transmission fluid, should be changed every 30k miles.
Have the new coolant, distilled or DI water, radiator flush, new t-stat and gasket, towels and rags, 5 ga bucket and large catch pan, and blue rtv on hand and ready to go.
This is a good time to check the water pump since your draining the coolant.
Safely and legally drain the coolant, remove the t-stat and put the housing back on. Put the radiator flush chemical per it's instuctions and fill the system with regular water. Run the engine per the instructions on the flush bottle, I just go for a 20 minute drive.
Let it cool down a bit and drain the system again. Backflush the heater core if you have heating problems. There should be a plug on the drivers side of the engine that you should remove to completely drain the engine of coolant. Put RTV on the plug thread when you put it back in the block.
Install the new t-stat in the correct position and gasket, blue rtv if necessary due to a corroded or uneven housing surface. Torque the bolts to spec, don't guess. Make sure all hoses and drain plugs are installed and tight, fill the system with 50/50 mix of coolant and distilled water.
Let the engine run to operating temp with the radiator cap off to help in removing air in the system.
Enjoy your new ride!
Old Feb 5, 2013 | 09:12 AM
FlagshipOne
Thanks John!...... whats 'blue rtv' ?
Old Feb 5, 2013 | 12:25 PM
lv2race's Avatar
lv2race
Permatex or something similar for water sealing applications. It's at any auto parts store for about $5-$10. Check the link.....
Gasket Makers : Permatex® Sensor-Safe Blue RTV Silicone Gasket Maker
Old Feb 5, 2013 | 12:38 PM
blkF250HD's Avatar
blkF250HD
Alternatively, get a few quotes from local shops on what a flush goes for. Where I work we have a machine that goes inline with one of the hoses, old coolant goes in and new coolant goes out. Also saves the hassle of trying to get rid of used coolant.
Old Feb 11, 2013 | 09:31 AM
FlagshipOne
local shop estimates run $120 to $150
Old Feb 11, 2013 | 10:38 AM
austinlittle34's Avatar
austinlittle34
use rmi25 best stuff in the world
choate
Sep 30, 2014 11:15 PM
Smokin'
15
Dec 11, 2006 07:21 PM
JR270
Feb 10, 2005 05:23 PM
DT 466Man
Nov 24, 2004 10:14 AM
mightypizu
Oct 15, 2004 04:04 PM
