CCV questions
Old Feb 7, 2013 | 05:05 PM
6.9lXLTf250's Avatar
6.9lXLTf250
CCV questions
can i re rount the ccv in the intake to another place on the truck? I know riff raff has one for the 99 thru 03 pstd and will that work? its the diy kit.
thanks
1994.5 7.3l
Old Feb 7, 2013 | 05:06 PM
dizzyfingers03's Avatar
dizzyfingers03
Are you putting on an Intercooler?
Old Feb 7, 2013 | 06:16 PM
96ford250's Avatar
96ford250
Flip the housing around so it points the other way then route the hose back to the fire wall and down anything directly behind the hose will get oil on it so route carefully
Old Feb 8, 2013 | 05:51 AM
mikec91's Avatar
mikec91
What's the deal if u got a intercooler ?
Old Feb 8, 2013 | 07:12 AM
96ford250's Avatar
96ford250
The oil from the CCV will leak into your intercooler and gum it up this mod is usually done before getting an intercooler
Old Feb 8, 2013 | 07:49 AM
fordpride's Avatar
fordpride
If you run your hose over the brake booster the down under the truck it'll stop 99% of the oil from coming out
Old Feb 8, 2013 | 03:33 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
The best way is to route it to a catch can and back into the intake. Then people will not look at you funny because your truck is smoking(just light oil vapor), and you will not smell the stink.
Here is how I did mine...
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Feb 8, 2013 | 09:45 PM
oldbird1965's Avatar
oldbird1965
Did you make that Justin or buy it?
Old Feb 8, 2013 | 10:54 PM
6.9lXLTf250
no intercooler yet, just tired of all the oil in the intake, can i buy a catch can? i bught the fiff raff kit for the ccv re route. Can i clean out the ccv?
Old Feb 9, 2013 | 02:30 AM
Justin@DP-Tuner
PREMIUM SPONSOR
I made the system myself. Less than $30 for everything. The catch can is from Tractor Supply($19.99).
__________________
Justin
www.dp-tuner.com
senix
6.4L Power Stroke Diesel
37
Mar 12, 2013 08:54 PM
caiati
Aug 16, 2012 04:21 AM
trekbasso
Feb 27, 2011 03:04 PM
joe blow
Mar 18, 2009 02:31 PM
StrokeThis96
18
Mar 5, 2008 10:28 AM
