Bright lights dont work
Old Feb 7, 2013 | 07:36 AM
caverjoe's Avatar
caverjoe
Well I am going down my country road last night and flipped the brights on and everything went dark.
The battery light had been flickering and the volt gauge running high when the bat light comes on. Last time that happened just meant the piece of crap NAPA Golds where going bad so I was just waiting for the slow crank, but that has not happend yet. Also kinda wiered.... when the battery light would stay on for a few seconds and the volt gauge would peg the electric windows would not work untill the light went out.
Got home late last night so did not try to search, searched for awhile this morning but couldnt find anything and I gottta go
Any ideas would be great.
thanks all
Joe
Old Feb 7, 2013 | 07:46 AM
thomabb's Avatar
thomabb
Sounds like you have an intermittent short somewhere.
Is it just your high beams that don't work? They are on their own fuse. That is step one.
If all the lights went out and the truck kept running, that is more serious. Can you please clarify?
Old Feb 7, 2013 | 01:02 PM
Smokiesman's Avatar
Smokiesman
I had the same problem on my 95 Mercedes and turned out to be the combo switch in the column! May not be the same for our trucks but ya never know??
Smokie
Old Feb 7, 2013 | 08:15 PM
caverjoe's Avatar
caverjoe
Well I found some time to poke around a little bit. I did not see anything obvious, checked the number 16 fuse it was fine. Been rainy here today so will have to find some time to look a little harder.
Too answer some previous questions.... only the high beams are not working. Truck kept running, the running lights stay on the highbeam indicator light on the dash comes on. I just loose all head lights when I switch to high beam, everything else seems to be working fine except the intermitent battery warning light.
Old Feb 8, 2013 | 02:35 AM
puller45's Avatar
puller45
Any possibility that one was already out and you didn't notice it till the other went? Not trying to be a wise a$$, just thinkin'.
Old Feb 8, 2013 | 06:52 AM
mueckster's Avatar
mueckster
Here is a pdf of the Headlamp wiring. Headlamp wiring.pdf
Old Feb 8, 2013 | 08:11 AM
Smokiesman's Avatar
Smokiesman
I believe on our trucks it is called a multifunction switch !
Smokie
Old Feb 8, 2013 | 08:25 AM
Rishsd's Avatar
Rishsd
[QUOTE=Smokiesman;12814182]I believe on our trucks it is called a multifunction switch !
Smokie[/
Old Feb 8, 2013 | 08:57 AM
BillyBob69's Avatar
BillyBob69
You did mention it has been raining the past few days....
Have you checked behind the fuse panel and the GEM to make sure you don't have the dreaded windshield leak and the GEM is getting wet?
Old Feb 8, 2013 | 09:05 AM
thomabb's Avatar
thomabb
Does flash-to-pass work as it should? Flash-to-pass lights the high beams without killing the low beams or fog lights.
Old Feb 10, 2013 | 12:39 AM
caverjoe's Avatar
caverjoe
No it does not work either, I also noticed that the highbeam indicator on the insturment panel only comes on in the flash to pass and not when I flip to high beam. I have not checked for the leak, hopefully I will get some time tomorrow to look a little closer
thanks for all the advice
Old Feb 10, 2013 | 08:28 AM
mueckster's Avatar
mueckster
That sounds odd. Look at the wiring diagram. The LG/BK wire going to the High Beams also also feeds the High Beams Indicator bulb in the instrument cluster. If power is going to the Indicator, you SHOULD have power at the Headlamps, unless there is a wiring/bulb issue. Have you checked for Power at the bulb plug wiring in Flash-to-Pass or High Beam? If you do have Power, it appears that a bad Headlamp Ground circuit is allowing the Low Beams to ground back through the High Beam Indicator wiring. A bad Ground could also be the cause of your Battery Light problem. I would check out all your Grounds next.
Old Feb 10, 2013 | 10:55 AM
caverjoe's Avatar
caverjoe
Thanks for all the help. I am still trying to find some time to get in there. Cold/rainy weather has me behind with my business trying to catch up on the weekends.
I think I am going to look at getting all new cables, I dont like the condition that my ends are getting in.
viper29
Jun 4, 2017 03:07 AM
Hoagland
Aug 21, 2012 09:41 AM
cbsquidss
Feb 21, 2008 04:05 PM
jimm66
1997 - 2003 F150
Feb 16, 2007 10:53 AM
jarat06
Apr 14, 2004 11:24 PM
