Lights flashing when on bright
Old Apr 14, 2004 | 11:18 PM
jarat06's Avatar
jarat06
My light's start flashing when I turn them on bright, If I turn on bright, they stay on for about 25 seconds, then start to flash. Now they have progressed to flash when on dim and when I am going about 30 mph....
I have recently changed the altinator, voltage regulator, and solonoid. It could be any of these things. Or I may not have the correct wires hooked up. help...please..
Old Apr 14, 2004 | 11:24 PM
Mil1ion's Avatar
Mil1ion
The breaker is integral to the switch.
Replace the headlight switch and install the upgrade so you have have the problem again & your headlights will work at higher efficiency.
http://faq.auto.light.tripod.com/headlamp-harness.html
