Hi guys, I have an intermittent problem with my mirror switch when trying to extend or retract the mirrors. I've taken it to the dealer but of course it works every time for then. I was wondering if anyone could tell me if the switch panel just pops off or is there some trick to get to the switch?
Rob17,
I replace the little speaker in my driver side rear door in 2011 crew cab.
You remove the visible screws and then lift the door panel straight up.
Then you can access the plugs on the back of the switches. Have your window down so you can get to the plugs easier. I'm sure the driver's door is very similar in assembly.
Well, I discovered that the switch panel pops off rather easily and the switch looks very easy to replace. But yikes, the dealer wants $80 for the switch!
