Emergency Flashers
Old Feb 6, 2013 | 10:40 AM
likeagoodbook's Avatar
likeagoodbook
Emergency Flashers
I've searched the forum and Google but I must be missing something simple, can anyone give me the trick to removing the emergency flasher switch from my 65 F100, I've read there's more than one type of switch but mine is located to the right of the steering wheel, mounted in the dash with the little light to the left. I can unscrew the bezel but it won't fit over the ****, the **** turns but doesn't seem to be unscrewing and I can't find a release button like the head light swithch has, there is a little slot in the back of the **** but pushing a screw driver into it doesn't seem to help and I don't want to force anything.
Thanks.
Old Feb 6, 2013 | 12:37 PM
schoo's Avatar
schoo
my 64 doesn't have e- flasher da.. should have bought 65
just took off all dash bezels and one cant remember which but it just pulled
but hard and came off
Old Feb 7, 2013 | 06:44 AM
likeagoodbook
Just an fyi to anyone interested, I figured this out, to remove the "****" from the emergency flasher switch, there's a small slot near the backside of the "****" push a small bladed screw driver into the slot while pulling the "****" straight out. Then you can unscrew the bezel and remove the switch from the backside.
Fydaman
Jan 27, 2012 03:15 PM
mike in nj
Aug 18, 2011 12:45 PM
334eagle
May 21, 2010 08:35 AM
ghspencer
Apr 8, 2006 01:56 PM
tmwindham
1978 - 1996 Big Bronco
Oct 24, 2004 12:10 AM
