In attempts to install my new deck in the glovebox. I attempted taking off the dash bezel and failed miserably..
I couldnt not get the lights switch **** off and the window wiper switch. I didnt want to risk scratching it or breaking it so i thought i would ask. Seems i have all the screws out already and all the ***** off the hvac and radio. Is the bottom portion just clipped in?
I used the search function. Please forgive me if i skipped over a post about this.
On top of the light switch assembly there's a little button about 1/8" in daimeter. Pull the **** out while pushing in on tis button and it will release the **** along with the rod. It will turn the lights on but you can push it down easily until the light go off but not enough to engage the look pin. Then simply pull it back out.
The wiper **** has a little spring clip that you have to reach in behind with a 90º bent tool of some kind you can make yourself. Pull the clip outward toward the **** as you pull on the ****...it will come right off.
At the bottom of the bezel there is a tab that fits into the dash right above the steering wheel. remove all the screws and pull out ward on the top. Then pull upward to remove.
