Howling turbo?
Old Feb 7, 2013 | 08:10 PM
99F350bigorange's Avatar
99F350bigorange
Originally Posted by diesel-fitter-bum01
I've had a howling issue for over a year now. I have pulled the turbo 3 times,installed alum intakes,RRD boots,swapped out innercooler,unhooked wastegate and screwed it tight,changed air intakes,and changed out the turbo wheel. I can't find it. Good luck
Can you at least build more then 5 pounds of boost?
Old Feb 7, 2013 | 08:15 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Yeah,low end boost takes forever,but I can max out my 35 psi gauge. Try taking your cac pipe off on the passenger side n brake boost it. See if it still howls. If it does that cancels everything after that. I think I need a new turbo. Currently throwing together a T4 setup. Hoping that fixes it. It's annoying.
Old Feb 7, 2013 | 08:24 PM
99F350bigorange
I think I could live with the howl if I could get some boost. Sucks not being able to hardly move.
Old Feb 7, 2013 | 08:44 PM
timmyboy76's Avatar
timmyboy76
subscribing...
Anyway of posting a vid of the noise? I've been experiencing a howling/harmonic sound, ever since my turbo blew up. Tried 2 different rebuilt turbos, and still have the noise. This April will be 2yrs ...
Old Feb 7, 2013 | 08:52 PM
99F350bigorange
Originally Posted by timmyboy76
subscribing...
I could try but I don't know if you'll be able to hear it. I gotta turn anything that makes noise in the truck down and listen. I'll see what I can do tomorrow. It's typically over 30 mph and higher rpms which is hard to accomplish with no boost.
Old Feb 7, 2013 | 09:02 PM
diesel-fitter-bum01
Really? Mines loud as heck.
Old Feb 7, 2013 | 09:08 PM
99F350bigorange
I've watched some videos of people's turbo and it's really loud but mine is very faint and intermittent.
Old Feb 7, 2013 | 09:13 PM
diesel-fitter-bum01
I can barely hear the turbo whistle over the howl sometimes. Yeah, it varies. One of these days I will try to get a vid,then figure out how to get it on here.
Old Feb 7, 2013 | 09:38 PM
JOHN2001's Avatar
JOHN2001
Not that I think it's your problem only being able to build 5psi of boost but it might help one of you guys... Check the driver side intercooler pipe by the power steering pump there's a square nut that's has a tendency to rub a hole in the pipe over time if its touching it
Old Feb 7, 2013 | 09:41 PM
99F350bigorange
I've had it off several times but it's all wrapped up didn't think about that. I'll have to check it out. Thanks!
Old Feb 8, 2013 | 04:49 PM
diesel-fitter-bum01
It won't let me upload my video. My tubes are ok,little wear from taking them in and out a hundred times.
Old Feb 8, 2013 | 04:54 PM
99F350bigorange
Can definitely tell it's been rubbing but no hole here either.
Old Feb 8, 2013 | 05:10 PM
  #28
diesel-fitter-bum01
Go to youtube and search 7.3l 38r turbo howl. that's what mine sounds like.
There's another video that says it's the thrust washer rubbing on the compressor housing. Makes me want to take my turbo apart,but not really.
gmcbride
Jun 10, 2012 05:32 PM
Spool&Go
137
Apr 19, 2012 11:22 PM
aklim
32
May 5, 2008 10:17 AM
richallen
Jul 23, 2005 06:41 AM
jrs_big_ford_f150
Dec 22, 2003 08:18 PM
