LED Bulbs
Old Feb 5, 2013 | 02:47 AM
drawtiteboy2's Avatar
drawtiteboy2
LED Bulbs
I purchased duel filament replacement LED bulbs for my 2004 F150 rear tails. They only blink on and off. I tried them in my chryler 300. They blinked faster, but worked. Why not in truck?
Old Feb 5, 2013 | 10:37 AM
parkland's Avatar
parkland
Some vehicles have flashing units where they require a certain power draw to activate the flashing sequence.
Usually LED tail light assemblies will have a resistor pack included to make them work.
Old Feb 5, 2013 | 11:49 AM
04XLTRUNNER's Avatar
04XLTRUNNER
Get some 6 ohm resisters from ijdmtoy.com or a autoparts place. go from high power side (blinker wire) to the ground side (black wire). This will pull any current left from the blinker circuit so the running lights will come on.
Old Feb 6, 2013 | 01:14 AM
papasmurf40's Avatar
papasmurf40
Ok we need schematic.....Please
Old Feb 6, 2013 | 07:12 AM
04XLTRUNNER
I'm posting from my phone so maybe someone else can pitch in. It's really simple though. The taillight bulb has 3 wires. Ground, low power (running light) and high power (blinking light). Just tap into to blinker wire and ground wire and your good. It's going to be the 2 outside wires that come out of the plug. Leave the center one alone.
Old Feb 6, 2013 | 10:05 AM
JoSHN's Avatar
JoSHN
Be careful for where you place the resistor for those LEDs too. They are known to get very hot. Hot enough to melt plastic at times. So... away from fuel lines, other electrical, and somewhere it will cool itself off.
Old Feb 6, 2013 | 10:57 AM
04XLTRUNNER
I have some for my switchbacks and they get a little warm but I don't think they would get hot enough to melt things. And there are no fuel lines by the tail lights so no worry there. Air moves through that area behind the tai lights while driving anyways.
Old Feb 6, 2013 | 12:57 PM
parkland's Avatar
parkland
I have resistor packs in plastic cases, and they barely get warm to the touch.
I think if you got real bad heat, somethings wrong.
Old Feb 7, 2013 | 08:49 PM
JoSHN's Avatar
JoSHN
It all depends on the type of resistor and what it is rated for. A crappy off the shelf typical resistor might not be suitable to handle these bulbs, especially if there are many leds run in parallel. I'd err on the side of caution anyways and still mount it off to the side.
Old Feb 7, 2013 | 10:10 PM
04XLTRUNNER
The resistors I use. They say they do get hot but mine just get a little warm to the touch.
http://store.ijdmtoy.com/50W-Load-Re...d_resistor.htm
Old Feb 7, 2013 | 11:27 PM
ford2go's Avatar
ford2go
Well, if they really are 50 watt, that's at least good design practice. Resistors should run at about half their rating, and 12 v x 2 amps ~ 24 w.
I have read elsewhere that they make LED flashers that run on the lower load. Unless they use this same trick internally, that might be a better deal -- provided that they're reasonably priced.
just a thought,
hj
zam
Aftermarket Products
Oct 4, 2016 07:33 PM
snake8myelbo
Electrical Systems/Wiring
Jan 20, 2015 03:54 PM
blockmanjohn
Mar 14, 2010 04:49 PM
48ATOY
Apr 5, 2006 10:56 PM
Hockycop
Mar 30, 2005 10:47 PM
