LEDs with a load equalizer?? need help
Old Mar 29, 2005 | 08:51 PM
Hockycop's Avatar
Hockycop
Hi all:
I just bought two LED light bulbs for the rear lights on my F-250. I also ordered LED load equalizers because the turn signals were flashing quickly with the LEDs. I tried to wire the laod equalizer with no luck. I sent an e-amil to the company and recieved the following responce;
"You must wire the LED's in parallel with one grounded. The best way I
know how to explain it is to pull up a diagram and look at that, I do
not have one to fax you though."
What does he mean by "in parallel with one ground".
Thanks for your help, Bob
Old Mar 29, 2005 | 10:24 PM
Franklin2's Avatar
Franklin2
I am not sure, but I would try hooking the equalizer across the LED. In other words, hook one side of the equalizer to the incoming voltage wire, and hook the other side to ground. This would put it in parallel with the LED lights, because one side of the LED is hooked to incoming power wire, and the other side is going to the light socket which is grounded to the truck sheetmetal.
Old Mar 30, 2005 | 10:55 AM
Bouts21's Avatar
Bouts21
A 1kohm resister between the two wires going to the signal light will do the trick
Old Mar 30, 2005 | 11:47 AM
Steina's Avatar
Steina
CO River Rat
Bob -
Check out http://autolumination.com/images/leds/installation.jpg
Steve
Old Mar 30, 2005 | 12:15 PM
Franklin2's Avatar
Franklin2
Would a electronic flasher drive those LED lights instead of using those equalizers? All those equalizers are for is a false load(resistors).
Old Mar 30, 2005 | 01:43 PM
Bouts21's Avatar
Bouts21
That's why they are needed, much less load on the circuit with the LEDs, when I did the LEDs in my Intrepid this is what I had to do.
Old Mar 30, 2005 | 02:06 PM
Franklin2's Avatar
Franklin2
The factory flashers work off the lighting load, but the electronic flashers don't. That is why I was wondering if the electronic flasher would work for the LED lights without the resistors.
Old Mar 30, 2005 | 06:39 PM
Hockycop's Avatar
Hockycop
Thank you very much guys, I think I know what to do now.
Steina, That diagram is just what I needed, I kinda thought that's what I needed to do but the load equalizer has two female plugs. It didn't make sence to plug it in that way with the plugs they supplied. Anyway, that should do it
Thanks again, Bob
Old Mar 30, 2005 | 10:47 PM
Bouts21's Avatar
Bouts21
Franklin2, when I put the LEDs in, they flashed fast, exactly as described, I queried it on a couple of Intrepid sites, and the people that had LEDs used the 1kohm resistor with success, I tried it and it worked for me too.
JimRay
Jul 8, 2017 08:31 PM
jgwatson109
General Automotive Discussion
Mar 23, 2016 10:08 AM
LaxPlaya21
Feb 26, 2016 10:40 AM
MLBaranowski
Nov 13, 2014 09:58 PM
sunuvabug
Electrical Systems/Wiring
Aug 14, 2007 07:47 PM
