C6 AUTOMATIC
Old May 10, 2014 | 08:04 PM
  #31
Shadowrider123's Avatar
Shadowrider123
Originally Posted by mikeb's66
No, two completely different valve body's.
Of course they are, but are they interchangeable?
I ask because they are on the early C-4's.
My 65 Mustang has the green dot shift pattern. If I swap in a 67+ C-4 valve body and the corresponding shifter bucket, I have a regular P-R-N-D-2-1 shift pattern.
Is the COM and C-6 the same?
Old May 10, 2014 | 08:13 PM
  #32
mikeb's66's Avatar
mikeb's66
Correct on the C4, but COM and C6 aren't even close to being the same. COM valve body is a little cube shaped valve body about 3-4" square while the C6 is a flat "boot shaped" valve body. You can interchange some C6 like C4 but that's about it.
Old May 10, 2014 | 09:57 PM
  #33
Shadowrider123
To bad, that would be to easy.
CalebJns
Nov 7, 2011 07:51 PM
fontime
May 14, 2011 07:46 PM
Redmanbob
May 28, 2008 08:39 AM
rmalottwtes30
Jul 29, 2007 08:20 PM
SloWave
Mar 29, 2002 03:32 AM
