I'm wanting to keep my factory column in my 48, but I want to loose the original wheel and replace it with an original(they make a smaller aftermarket) 1959-1960 Chevy Impala wheel. Will it bolt up or do I need an adapter or will it even work? I've saw the grant adapter kit to make an aftermarket wheel work but since this is a factory chevy wheel I wasn't sure what I would run into.
Nice idea but it won't fit and as far as I know there is no adapter that will make it fit. Short of replacing your column with a 59/60 GM colum, you will have to fabricate something yourself...
That is what I was afraid of!!! I just bought a nice used 59 wheel on ebay last night too I do have a spare column so I've got a test product to play with, not sure if I can figure anything out or not though, guess we will see!
As GNW says there is no one making an adapter for the Ford column spline/nut mounting system to GM or any aftermarket wheel, and if they did it would be difficult to adapt the horn button on the new wheel. No sense using the stock column unless you have rebuilt the steering box (it's all one piece, and the original box is usually shot.) There are aftermarket companies making inexpensive (non tilt) stock looking replacement columns that take a standard GM wheel mounting, or you can use a later model GM column and adapt it to the steering box of your choice with a compatible U joint.
Hope you don't have too much invested in the wheel. If you decide you want to sell it I may be interested. I have a 54 Chevy in mind that may require some tinkering....
That may be the route I go then, Call be crazy but I don't really want a tilt column, I want to keep the original look of the stock column. I am running a stock box, the one in the truck is shot but I have a spare box that is good(well supposed to be). May look into one of those columns!
I felt like I got a good deal, about 100 shipped but it doesn't have the center piece. But it works out perfect because I have one. The reason I want a 59 wheel is because my late uncle(previous owner of my 48) also had a brand new 1959 Chevy Impala, 348, 3 dueces, fender skirts, the works. Anyway when I was cleaning out behind the seat of my truck a few years ago I found the center piece for a 59 wheel, I can only assume it was off his car, maybe broke off and got tossed in the truck. So when I saw the wheel on ebay missing a center piece I knew without a shadow of a doubt I had to have it!
