Sponsored by: Auxito
starter
Old Feb 3, 2013 | 10:45 PM
jdq's Avatar
jdq
starter
So changing the starter looks like its going to be a bear lol
i read a couple threads , any other tips other than a long extension on ratchet. 2002 f 150
Old Feb 4, 2013 | 05:17 AM
projectSHO89's Avatar
projectSHO89
Disconnect the battery negative terminal.
Put the right front corner on a jack stand and pull the right front wheel. Otherwise, getting to the top bolt is a bear.
A set of 6-point impact sockets is suggested to keep from rounding off the bolt heads.
Old Feb 4, 2013 | 09:07 AM
jdq's Avatar
jdq
thanks i appreciate it
Old Feb 4, 2013 | 01:17 PM
Spotty's Avatar
Spotty
If you can take another 10 minutes or so, pull the inner plastic fender off too. Man...a new world opens up. As stated...only use 6-point. Give a little tap on the end of the extension before you try to loosen them. Once they break loose if they really, really back out stiff, spray some PB on em' and run them back in a few threads. Man.....you don't want to snap one off....you''ll be fine....take her slow.
Old Feb 4, 2013 | 05:19 PM
jdq's Avatar
jdq
thanks again , taking the tire off made all the difference in the world.
Old Feb 4, 2013 | 05:41 PM
Spotty's Avatar
Spotty
Did you get it all done then...?
Old Feb 4, 2013 | 07:05 PM
jdq's Avatar
jdq
yes , got er done thanks.
ive done one before on other car , but wasnt this bad to get at haha
Old Feb 4, 2013 | 07:11 PM
Spotty's Avatar
Spotty
Good to hear.....
bigreentruck
Dec 5, 2016 05:02 AM
Whitey Ford
13
Oct 2, 2015 01:31 PM
BubbaBud
Sep 21, 2014 10:48 AM
mike5097
Oct 13, 2005 10:37 PM
cantrma
3.8 & 4.2L V6
Jan 17, 2005 08:19 PM
