I've thought seriously about slipping a 440 under the hood since it would bolt right in. And, maybe even the 6 pack setup - hey, 2bbls are good for gas mileage, right?
Really though, it won't be numbers matching. It'll just be a hot rod, so why not be HOT. Back in the day my Bee got 14 MPG on the highway, and I can't imagine not being able to get at least 12 with a 440. It isn't going further than a few local car shows, so even 10 would be acceptable.
Oh yes, and a Pertronix ignition to get rid of the points. Maybe a headlight relay setup 'cause Mother Mopar did the same thing Ford did but worse - not only does all the current for the headlights run through the switch, but they put a connector on the firewall. The police cars and taxi cabs had the main feed bypassing the connector as they are notorious for failing. But, on my Bee the current for the poor headlights has to go in via the connector, through the switch, and back out via the connector. So, a set of relays is in the offing, but hidden somewhere.
Well since we drifted into Mopar land... My cousin picked this up for a song a couple years ago ($1,500 IIRC). It's a Jepson Interceptor with a stroker 440 six pack... 520 or 525ci. Torque flight trans and I think 8 3/4 rear... This was shot with open headers. He's got an old Plymouth street rod (40's?) with a custom frame under it. Strut front end with a 4 link rear, tubbed out. It was setup for a 454 but he changed it up for the 440...
That's cool! It'll be a good fix for the Plymouth - I don't like cross-branded hot rods. Waaaay too many 350/350 combo's out there in all sorts of cars.
But, the Jensen needs to live again as well. IIRC, they came with a stock 330 HP 383 or a 440. So, maybe stuff one of those in and get it on the road also?
I always hated retrofit low mounted gauges. I have them in my car and don't check them often. Typically at startup, after beating on it, or if something seems not right.
On my truck I put them in the dash. Looks clean, right in your face, and easy to constantly check at a glance. Saved me from killing my engine after it developed an oil leak and ran low, gauge fluttered on the highway at speed and quickly pulled over and topped off, then fixed the leak that night.
Anyhow, if your truck doesn't have air conditioning, I'd suggest this for a simple and effective solution...
There was a big, long thread begun here several years ago about white-face gauges that was my inspiration, the full HOWTO on how I did that is HERE if you're interested.
