Reshaping front leafs??
Old Feb 5, 2013 | 07:57 PM
Diesel_Brad's Avatar
Diesel_Brad
Well, when the manufacture tells you it WILL NOT WORK, that is a pretty good inclination. I am sure if they could sell more IF it worked on TTB, but they don't
Right off SKYs site
"FORD F-350 SHACKLE REVERSAL KIT INSTRUCTIONS
*******This kit is for 1992-1997 monobeam axle trucks only*******
Right off ORUs site
This kit is designed for straight axle's only, will not work with IFS."
But also the TTB axle is designed with the shackle in the FRONT. when you move it to the rear, it causes the axle to Bind under articulation
Old Feb 5, 2013 | 08:00 PM
joshh's Avatar
joshh
well ive seen it done it does work
also like i said before the geomentry has to be right just like any axle mod
Old Feb 5, 2013 | 08:07 PM
Diesel_Brad
What do they know, they only make the kit
Old Feb 5, 2013 | 08:09 PM
joshh's Avatar
joshh
im not gonna argue with u but rember i said the kits offeded wont work without mods. they chose to build it that way
and op sorry for messing up the thread
Old Feb 5, 2013 | 08:12 PM
Diesel_Brad
You are right and the MOD is to put a dana 60 axle in. Then it works fine
Old Feb 6, 2013 | 06:15 PM
bluemtn95ford's Avatar
bluemtn95ford
Wish I had unlimited cash and I'de try both and see who's right lol.
It's fine guys I'm thinking of leveling my truck any way. Is there anyway I can buy new springs that will lift my truck enough to do this at the same time? Other than SD springs.
Thanks yall
Old Feb 6, 2013 | 06:31 PM
bluemtn95ford
Here's a pic showing the rake pretty well... Ground looks uneven but it's pretty level.
Old Feb 6, 2013 | 06:34 PM
Diesel_Brad
You can go with an add-a-leaf or go with New springs. Dont forget, your springs are 18 years old and worn out
Old Feb 6, 2013 | 06:47 PM
bluemtn95ford
What would you say about an add a leaf? Maybe one of around 2"s?
Thnxs again...
Old Feb 6, 2013 | 07:34 PM
Diesel_Brad
1 to 1.5" at most
Old Feb 6, 2013 | 07:39 PM
bluemtn95ford
Alright I'll look into it. Thanks for your help Brad
nothercrash
17
Jul 7, 2019 12:33 PM
jdasilva644
Apr 15, 2010 10:02 PM
wilbur996
Apr 4, 2010 10:00 AM
1952
Oct 13, 2003 08:50 PM
james3
Apr 9, 2003 02:04 PM
