Reshaping front leafs??
Old Feb 2, 2013 | 06:47 PM
bluemtn95ford's Avatar
bluemtn95ford
So my Truck has about an inch more sag on the right front than the left. It's really bugging me because it effects the looks real bad. I'm guessing my leafs a tired and was wondering what it would cost to have them reheated and shaped. And if it's worth it. Also, would this help with my rake problem too? It's at least 2 inches. Thanks ya'll
Old Feb 2, 2013 | 06:49 PM
Diesel_Brad's Avatar
Diesel_Brad
If you heat a spring you take the tension out of it and it is no longer a spring.
But if you are talking about rearching them, it is a waste of time and money. They just settle back after about 6 months. Just buy new springs if yours are shot
Old Feb 2, 2013 | 06:58 PM
bluemtn95ford
Sorry, I was talking re-arch.
Should I buy new or junk yard?
Old Feb 2, 2013 | 08:06 PM
bluemtn95ford
Also what yr trucks could I take the front leafs off and make work? Thnxs
Old Feb 2, 2013 | 09:27 PM
Diesel_Brad
1980-97 are the same. You will not want used ones though, they will moist likely be as bad as yours
Old Feb 2, 2013 | 11:00 PM
bluemtn95ford
Ok thanks that's what I needed to know
Old Feb 2, 2013 | 11:29 PM
DIYiT's Avatar
DIYiT
Another route is to upgrade to Super Duty leaf springs with an RSK. Side effects are a 2+ lift depending on the RSK and leafs chosen, a better ride, and the need to move the front spring hanger forward for the longer springs.
Brad's got a nice build thread with pictures of both his SKY Manufacturing and Precision Metal Fab RSKs.
Old Feb 3, 2013 | 07:20 AM
Diesel_Brad
The problem is he has a D50TTB and you cant use s aRSK with one, you need a solid axle
Old Feb 3, 2013 | 09:25 AM
joshh's Avatar
joshh
i would take a little work to keep geomentry right but u could use a rsk setup on a ttb if op wanted to do it
Old Feb 3, 2013 | 09:49 AM
buzzy613's Avatar
buzzy613
is there any other way to lift the front of ttb? like the leavaling kits sky jacker maked i think the add a leaf? do they work well? sorry for thread jacking
Old Feb 3, 2013 | 03:03 PM
joshh's Avatar
joshh
im running an add a leaf on mine and it seems to ride better than most stock trucks ive drove(including my buddies 350 cc long bed ) and front is bout 1/2" higher than the rear now will fix that one day
Old Feb 3, 2013 | 03:34 PM
buzzy613's Avatar
buzzy613
ill have to save up them then thanks josh
Old Feb 4, 2013 | 10:21 PM
bluemtn95ford
Alright, whats an RSK? and if that's possible I'de like to raise my front about 2" to even it out with my front. If superduty springs are possible I'll try it.
Old Feb 5, 2013 | 08:05 AM
Diesel_Brad
I will say it again, you can NOT run a RSK with the TTB
Reverse Shackle Kit
Old Feb 5, 2013 | 07:37 PM
joshh's Avatar
joshh
so exactally why do u say u cant run it with the ttb? and i agree the normal kits that give 2+ inches of lift wont work without relocating the ttb pivot points. a kit can easily be made to only give an inch or so that would work just fine, its been done before .Also i'm pretty sure there is a guy on here that did it.
