89 f250 front spring question
Old Feb 2, 2013 | 03:48 PM
impalaslayer's Avatar
impalaslayer
so i have an 89 f250 and i put in a dana 60 from a 350, went in no problems been riding around like that for about 6 months now. i used everything from the 350 including the springs
heres my question, my front end sits too high now by about 2 inches past level and it drives me crazy the way it looks. i really dont want to lift the rear as i have no interest in putting bigger tires on it and plan to tow things with it.
heres my question, is it possible to run the old ttb springs with the 60? i know they will bolt up but ive always read to run the ones for the solid axle. i want my truck to sit about level or even with a slight nose down rake like stock was.
thanks, dave
Old Feb 2, 2013 | 05:23 PM
bashby's Avatar
bashby
F350's have a bigger "lift blocks" in the rear. If you get those it should get you sitting right again.
Old Feb 2, 2013 | 05:35 PM
Diesel_Brad's Avatar
Diesel_Brad
You "can" use f250 springs, but you might as well just run no suspension.
They are actually a HIGHER spring rate than F350 springs by over 1,200lbs
like bashby said, use the f350 4" block in place of the F250 2" blocks to bring the rear up
Old Feb 2, 2013 | 06:07 PM
92blue on uhhhh blue's Avatar
you could try cutting a coil or a half coil just dont do it with a blow torch and know that it will affect the spring rate
Old Feb 2, 2013 | 06:47 PM
Diesel_Brad
PLEASE stay out of a thread when you have NO CLUE what you are talking about
Old Feb 2, 2013 | 06:53 PM
blkF250HD's Avatar
blkF250HD
Pssst......4wd F250s and F350s used leaf springs in the front. Only the 2wds used coils. F150's had coils on both 4wd and 2wd.
Old Feb 2, 2013 | 11:48 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Interesting. Didn't know the F250 negative arch springs had a higher spring rate than the F350 ones.
Old Feb 3, 2013 | 08:30 AM
tjc transport's Avatar
tjc transport
i ain't rite
stiffer springs for the flex of the ifs John.
Old Feb 4, 2013 | 09:03 PM
impalaslayer
this is pretty much what i was told, looks like its lift the rear it is. thanks all.
Old Feb 5, 2013 | 08:38 AM
tjc transport
i ain't rite
if you are going to be running a commercial snow plow, leave the 250 springs in it for the added support. otherwise switch to the 350 springs for the smoother ride.
Magnolia Tom
Jan 30, 2014 10:21 AM
kidkyle21
23
Feb 1, 2013 07:54 PM
95f2504x4
Apr 15, 2012 08:31 AM
micksjen
May 19, 2007 12:25 AM
pud
Nov 29, 2006 09:26 PM
