V/B spring question
Old Jan 5, 2014 | 10:44 AM
Magnolia Tom's Avatar
Magnolia Tom
V/B spring question
His may be a dumb question but what is the reasoning for modifying the rear springs on the excursion? Why not just use the springs from the f250 as they are? I'm deciding whether I need to do this and would like a little information on the "why" not just the "how".
Thanks
Old Jan 5, 2014 | 11:26 AM
Stewart_H's Avatar
Stewart_H
To eliminate the need to also upgrade the rear blocks to the bigger blocks found on the F250/350's
Mod the spring pack and you can re-use the stock Excursion blocks, keeping the same front-to-back rake.
This is assuming a person also is upgrading the front suspension by swapping in a set of V codes up front.
Stewart
Old Jan 5, 2014 | 12:42 PM
Magnolia Tom
Thanks Stewart.
Old Jan 5, 2014 | 04:55 PM
powerram50's Avatar
powerram50
how do you modify the springs?
Old Jan 5, 2014 | 05:00 PM
Stewart_H's Avatar
Stewart_H
You make a modded B spring by taking the two shortest leaves from the Excursion spring packs and add them to the B code spring pack, placing the leaves between the shortest leaf of the B code, and the bottom overload leaf. You also remove the sheet metal spacers that came on the B codes and replace them with the 1/8" spacers from the Excursion springs.
Stewart
Old Jan 5, 2014 | 06:18 PM
sandfarmer's Avatar
sandfarmer
Stewart
Now there's some quality info! You sir just got a rep!
Old Jan 5, 2014 | 07:11 PM
VQT's Avatar
VQT
Stewart is the V/B guru for our Excursion.
Old Jan 5, 2014 | 09:49 PM
Stewart_H's Avatar
Stewart_H
Thanks, I appreciate the thought.
Honestly though, I like to think the collective brain trust here in the Ex forum is why we can help so many people with the common spring problem the 4x4 Excursions have.
Nothing beats the hands on experience of all these guys here who have done variations, mutations, and different creations of the commonly referred to V code/B code mod!
I do appreciate your sentiment though, thanks!
Stewart
Old Jan 5, 2014 | 09:50 PM
timf150's Avatar
timf150
If you did a v/b swap without modifying the rear springs it may measure as being the same height but you get the illusion of the rear of the X sitting low (sagging) which does not look right.....not the proper rake as mentioned by Stewart.
Tim M
Old Jan 5, 2014 | 10:12 PM
wpnaes's Avatar
wpnaes
Sag, or as the So Cal guys like to say 'bro lean'...
Old Jan 5, 2014 | 11:02 PM
powerram50's Avatar
powerram50
i will need to remember this.thanks.or you can just run the bigger spacer from the truck right?
Old Jan 5, 2014 | 11:05 PM
Stewart_H's Avatar
Stewart_H
Yes.
All of the suspension mod information is listed in the Excursion Forum Tech Folder thread stickied at the top of the Excursion forum page.
Stewart
Old Jan 29, 2014 | 10:50 AM
crazytwo's Avatar
crazytwo
I was looking at my rear suspension and comparing it to a F250. There is a difference between the two. The ex has something like a half leaf pointing to the front with a disintegrated rubber bump stop and the F250 doesn't. Why the difference? It reminds me of traction bars I used to see many years ago. Also, any suggestions on a replacement for the rubber/plastic stops?
Old Jan 29, 2014 | 02:47 PM
robert_l_ross's Avatar
robert_l_ross
That's a leaf to prevent the axle from wrapping when you accelerate. When you hit tje gas, the axle wants to wrap (drive shaft side wanting to go up and over) so that bar stops the axle from wrapping backwards, keeping everything lined up. With the B or Modded B, the spring is stiffer and isn't as subject to the wrap, so it typically isn't needed.
If you are referring to the actual frame mounted bump stops...you can still find some around, and suspension shops might carry aftermarket ones. Couldn't give you manufacturers since mine were OK so I'm still on the stock ones.
Old Jan 29, 2014 | 03:02 PM
LivingLarge's Avatar
LivingLarge
Ford still has them, pretty cheap part. I replaced mine couple months back.
